[gdal-dev] Reprojection issue that works in GDAL 2.4.0 but not 3.0+
Even Rouault even.rouault at spatialys.com
Tue Jan 21 08:09:07 PST 2020
Brian,
> I am trying to go from (this is the .prj from an ESRI shapefile)
> PROJCS["USA_Contiguous_Albers_Equal_Area_Conic_USGS_version",GEOGCS["GCS_Nor
> th_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137.
> 0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]]
> ,PROJECTION["Albers"],PARAMETER["False_Easting",0.0],PARAMETER["False_Northi
> ng",0.0],PARAMETER["Central_Meridian",-96.0],PARAMETER["Standard_Parallel_1"
> ,29.5],PARAMETER["Standard_Parallel_2",45.5],PARAMETER["Latitude_Of_Origin",
> 23.0],UNIT["Foot_US",0.3048006096012192]]
> to EPSG:4326
Can you share the shapefile, and the command line you use ?
Even
http://www.spatialys.com
