[gdal-dev] OGRCreateCoordinateTransformation problem on GDAL 3.0.3 and PROJ 6.3.0
Edzer Pebesma edzer.pebesma at uni-muenster.de
Thu Jan 23 08:40:04 PST 2020
On 1/23/20 5:29 PM, Sean Gillies wrote:
> Hi,
> On Thu, Jan 23, 2020 at 8:01 AM Edzer Pebesma
> <edzer.pebesma at uni-muenster.de <mailto:edzer.pebesma at uni-muenster.de>>
> wrote:
>     The combination of GDAL 3.0.3 and PROJ 6.3.0 arriving on debian
>     platforms is causing some havoc for some spatial R packages. I could
>     bring one particular problem back to the following C++ program:
>     #include <stdio.h>
>     #include "ogrsf_frmts.h"
>     #include <ogr_spatialref.h>
>     int main() {
>        OGRSpatialReference *aSRS = new OGRSpatialReference;
>        OGRSpatialReference *bSRS = new OGRSpatialReference;
>        char *pszSRS = NULL, *wkta = NULL, *wktb = NULL;
>        aSRS->importFromProj4("+init=epsg:4326");
>        aSRS->exportToPrettyWkt(&wkta);
>        aSRS->importFromWkt((const char *) wkta);
>        bSRS->importFromProj4("+init=epsg:3857");
>        bSRS->exportToPrettyWkt(&wktb);
>        bSRS->importFromWkt((const char *) wktb);
>        OGRCoordinateTransformation *ct =
>     OGRCreateCoordinateTransformation(aSRS, bSRS);
>        if (ct == NULL) {
>             printf("ct NULL\n");
>             exit(1);
>        exit(0);
>     which outputs:
>     Warning 1: +init=epsg:XXXX syntax is deprecated. It might return a CRS
>     with a non-EPSG compliant axis order.
>     ERROR 1: PROJ: proj_create_operations: At least one of the operation
>     lacks a source and/or target CRS
>     ERROR 6: Cannot find coordinate operations from `GEOGCRS["WGS
>     84",DATUM["World Geodetic System 1984",ELLIPSOID["WGS
>     84",6378137,298.257223563,LENGTHUNIT["metre",1]],ID["EPSG",6326]],PRIMEM["Greenwich",0,ANGLEUNIT["degree",0.0174532925199433],ID["EPSG",8901]],CS[ellipsoidal,2],AXIS["longitude",east,ORDER[1],ANGLEUNIT["degree",0.0174532925199433,ID["EPSG",9122]]],AXIS["latitude",north,ORDER[2],ANGLEUNIT["degree",0.0174532925199433,ID["EPSG",9122]]]]'
>     to `PROJCRS["WGS 84 / Pseudo-Mercator",BASEGEOGCRS["WGS 84",DATUM["World
>     84",6378137,298.257223563,LENGTHUNIT["metre",1]]],PRIMEM["Greenwich",0,ANGLEUNIT["degree",0.0174532925199433]],ID["EPSG",4326]],CONVERSION["unnamed",METHOD["Popular
>     Visualisation Pseudo Mercator",ID["EPSG",1024]],PARAMETER["Latitude of
>     natural
>     origin",0,ANGLEUNIT["degree",0.0174532925199433],ID["EPSG",8801]],PARAMETER["Longitude
>     of natural
>     origin",0,ANGLEUNIT["degree",0.0174532925199433],ID["EPSG",8802]],PARAMETER["False
>     easting",0,LENGTHUNIT["metre",1],ID["EPSG",8806]],PARAMETER["False
>     northing",0,LENGTHUNIT["metre",1],ID["EPSG",8807]]],CS[Cartesian,2],AXIS["(E)",east,ORDER[1],LENGTHUNIT["metre",1,ID["EPSG",9001]]],AXIS["(N)",north,ORDER[2],LENGTHUNIT["metre",1,ID["EPSG",9001]]]]'
>     ct NULL
>     What am I doing wrong?
> If you pass "EPSG:4326" to importFromProj4 instead of "+init=epsg:4326"
> (and likewise for EPSG:3857) the deprecated syntax warning won't be
> printed. I expect that the error would be cleared up too, at least that
> is my experience with the latest in these libraries.
Thanks! Yes, with SRS->importFromUserInput("EPSG:3857"); etc this works
fine; I'm OK with the warning, I just don't see how the subsequent error
relates to syntax that is deprecated.
Edzer Pebesma
Institute for Geoinformatics
Heisenbergstrasse 2, 48151 Muenster, Germany
Phone: +49 251 8333081
Type: application/pgp-keys
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200123/0d346557/attachment-0001.key>
