[gdal-dev] Python Wheels for gdal
Christoph Paulik cpaulik at vandersat.com
Thu Jan 30 04:09:03 PST 2020
Thanks for the hints Even. I could have thought about rasterio myself since
I've used their wheels in the past.
Are you open to a merge request for setting this up for the official gdal
python packages?
Christoph
On Thu, 30 Jan 2020 at 12:59, Even Rouault <even.rouault at spatialys.com>
wrote:
> On jeudi 30 janvier 2020 11:15:35 CET Christoph Paulik wrote:
> > Hi,
> > Has anybody ever tried to build Python wheels for gdal?
> https://github.com/rasterio/rasterio-wheels could serve as a starting
> point
> There's also https://www.lfd.uci.edu/~gohlke/pythonlibs/ for Windows
> > I'm thinking about it but am not sure if it would even be possible with
> all
> > the dependencies that gdal has to make a `pip install gdal` work without
> > problems.
> You clearly have to decide which GDAL dependencies you bundle or not...
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
*Christoph Paulik* // Head of Infrastructure
VanderSat // Satellite observed water data. Globally. Daily.
Wilhelminastraat 43a, 2011 VK, Haarlem (NL), The Netherlands
<https://maps.google.com/?q=Wilhelminastraat+43a,+2011+VK,+Haarlem+(NL),+The+Netherlands&entry=gmail&source=g>
*M*  +31 6 18271928 *W*  www.vandersat.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200130/f0d5785c/attachment.html>
