[gdal-dev] Python Wheels for gdal
Patrick Young patrick.mckendree.young at gmail.com
Fri Jan 31 06:05:38 PST 2020
Here is how I build them for Linux, taken from Sean's work on rasterio.
https://github.com/youngpm/gdalmanylinux
On Fri, Jan 31, 2020, 2:58 AM Christoph Paulik <cpaulik at vandersat.com>
wrote:
> Thank you all for the input.
> My initial motivation was that I would like `pip install gdal` to just
> work.
> I like and use conda-forge daily but in my opinion the whole Python
> packaging system is broken.
> There are packages you can install with conda but not with pip and the
> other way around.
> So you always need to mix and match which leads to another set of problems.
> Especially if you have your own Python package that depends on gdal.
> You need to put it on conda-forge or your own channel which can be a long
> process and extra work for every release
> so that the installation works reasonably well for your users.
> I guess that it is unrealistic to fix any of that, so let's get back on
> topic.
> I'll probably try to see if I can get a working wheel using the work that
> was already done as a basis.
> If I have any news to share I'll let you know. But you might never hear
> from me again on this topic.
> Christoph
> On Thu, 30 Jan 2020 at 18:40, Mateusz Loskot <mateusz at loskot.net> wrote:
>> On Thu, 30 Jan 2020 at 18:03, jratike80
>> <jukka.rahkonen at maanmittauslaitos.fi> wrote:
>> > Sorry if this is a stupid question, but would GDAL wheels serve some
>> similar
>> > purpose than what gdal in conda-forge is serving
>> > https://anaconda.org/conda-forge/gdal/files?
>> https://www.anaconda.com/understanding-conda-and-pip/
>> Best regards,
>> Mateusz Loskot, http://mateusz.loskot.net
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> *Christoph Paulik* // Head of Infrastructure
> VanderSat // Satellite observed water data. Globally. Daily.
> Wilhelminastraat 43a, 2011 VK, Haarlem (NL), The Netherlands
> <https://maps.google.com/?q=Wilhelminastraat+43a,+2011+VK,+Haarlem+(NL),+The+Netherlands&entry=gmail&source=g>
> *M*  +31 6 18271928 *W*  www.vandersat.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200131/d48801c6/attachment.html>
