[gdal-dev] A crash with 3..1.1
Joaquim Manuel Freire Luís jluis at ualg.pt
Wed Jul 1 02:33:18 PDT 2020
And sorry again for not reporting everything in same post. It happens also in the CI tests
https://github.com/GenericMappingTools/gmt/issues/3566
and just got one more info
GDAL 3.1.0 fine, 3.1.1 crash
Either macports or homebrew
Seems to involve Geotiff.
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Joaquim Manuel Freire Luís
Sent: Wednesday, July 1, 2020 10:28 AM
To: Even Rouault <even.rouault at spatialys.com>; gdal-dev at lists.osgeo.org
Cc: Paul Wessel <pwessel at hawaii.edu>
Subject: Re: [gdal-dev] A crash with 3..1.1
No, not build directly from source. I believe it's a GDAL supplied by Macports but Paul is at Hawaii and sleeping now, so can't confirm. And I forgot to mention in previous post. No problem when using GDAL 3.1.0 (same origin)
From: Even Rouault <even.rouault at spatialys.com<mailto:even.rouault at spatialys.com>>
Sent: Wednesday, July 1, 2020 10:22 AM
To: gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
Cc: Joaquim Manuel Freire Luís <jluis at ualg.pt<mailto:jluis at ualg.pt>>; Paul Wessel <pwessel at hawaii.edu<mailto:pwessel at hawaii.edu>>
> Any idea on what might be causing this?
As it seems this involves building GDAL from source, and possibly from the same tree, perhaps a missing "make clean" before different build attempts
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200701/80a654b1/attachment-0001.html>
