[gdal-dev] undefined reference to `json_object_new_array linking with libgdal.a
Luí­s Moreira de Sousa luis.de.sousa at protonmail.ch
Wed Jul 22 11:38:55 PDT 2020
Hi again Even,
I work with GDAL installed from the Ubuntu GIS repository. I could not verify, but I doubt it is compiled with the --with-hide-internal-symbols flag.
This programme includes the Makefiles, I am just trying to compile it with minimal change. I experimented removing the link to shapelib.a, but then none of the shapefile methods are found. So it seems the compiler it is not confusing it with the methods in GDAL.
I hope this is not straying too much from GDAL itself. It has been a few years since I last compiled this programme, but it used to be just plug-and-play.
Thank you.
Luís
Sent with [ProtonMail](https://protonmail.com) Secure Email.
‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
> Ah sorry I read your initial message too fast. I thought you had an issue building GDAL itself.
> The SASetupDefaultHooks issue might come from it being defined in shapelib.a and in GDAL too.
> Did you build GDAL with --with-hide-internal-symbols ?
> Any reason to use static linking ? This is generally an extra pain
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200722/2e289f7d/attachment-0001.html>
