[gdal-dev] c# bindings - osr SpatialReference constructor
Paul Harwood runette at gmail.com
Tue Jun 16 12:30:52 PDT 2020
Cool, thanks!
On Tue, 16 Jun 2020, 19:12 Tamas Szekeres, <szekerest at gmail.com> wrote:
> You should use null in the constructor if you don't want to specity a wkt
> during the initialization, something like:
> *SpatialReference srs = new
> SpatialReference(null);srs.ImportFromEPSG(2927);*
> Best regards,
> Tamas
> Paul Harwood <runette at gmail.com> ezt írta (időpont: 2020. jún. 16., K,
> 19:01):
>> A common pattern for creating a SpatialReference is this :
>> from osgeo import osr
>> spatialRef = osr.SpatialReference()
>> spatialRef.ImportFromEPSG(2927)         # from EPSG
>> ( this example is from the Python Cookbook and is just used to illustrate
>> the pattern)
>> But - when I try to do the equivalent in c# using the bindings :
>> SpatialReference CRS = new SpatialReference();
>> CRS.ImportFromMICoordSys(coordsys);
>> I get a message
>> error CS1729: 'SpatialReference' does not contain a constructor that
>> takes 0 arguments
>> Am I missing something? Or is this is a gap in the bindings?
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200616/eca344ee/attachment.html>
