[gdal-dev] Slope obtained with GDAL has weird lines
Joaquim Manuel Freire Luís jluis at ualg.pt
Mon Mar 16 17:32:13 PDT 2020
Ah, let me guess. The dem grid was interpolated from contour lines and you seeing the contours again.
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Danilo da Rosa
Sent: Monday, March 16, 2020 11:09 PM
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] Slope obtained with GDAL has weird lines
Hi!
This may be a very basic question, but I can't find the answer anyware.
I am working with this DEM obtained using terraincache<https://pypi.org/project/terraincache/>, it uses mapzen data. The SRC is WGS 84.
[DEM File in QGIS]<https://i.stack.imgur.com/Sp4Sg.jpg>
I ran this GDAL command to get the slope:
gdaldem slope -s 111120 dem.tif slope.tif (I had to do scaling because of the SRC)
The resulting image looks fine but it's not smooth, it has weird lines over it, like contour lines.
[Slope file on QGIS]<https://i.stack.imgur.com/POcHR.jpg>
You can download the DEM file here: https://gofile.io/?c=Du7WnM
Does anyone have an idea of how to solve it?
Thanks in advance for your help,
Danilo
P.S. I made this question here too: https://gis.stackexchange.com/questions/353983/slope-obtained-with-gdal-has-weird-lines
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200317/60e89f57/attachment.html>
