[gdal-dev] gdalwarp results differ in different gdal versions?
Meghan Burris emmburris at gmail.com
Fri May 8 11:36:47 PDT 2020
Hello!
I'm hoping someone can shine some light in my direction because I can't
find any answers.
I'm trying to warp a Polar Stereographic image into an Equal Cylindrical
projection. When I run the gdalwarp command on older versions (specifically
1.8.1), my image looks as I would expect. When I run the same command in
gdal versions 2.2.4 or 2.4.1, the pole is clipped out and missing. I've
tried adding different parameters such as -te, and multiple -wo parameters
and nothing works for me. Am I missing something? Any help would be greatly
appreciated because I can't use the older versions anymore in my script. My
original warp command is below as well as the original polar header.
Although, I have tried multiple images and I still don't get the results
that I was getting in version 1.8.
Thank you in advance!!
Meghan
gdalwarp -overwrite -of GTiff -t_srs "+proj=eqc +a=3375.0 +b=3375.0
+towgs=0,0,0,0,0,0" input.tif output.tif
Driver: GTiff/GeoTIFF
Files: SP_MY34_summer_18mpp_gd2.tif
Size is 35928, 35815
Coordinate System is:
PROJCS["unnamed",
    GEOGCS["unnamed ellipse",
        DATUM["unknown",
            SPHEROID["unnamed",3396000,0]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433]],
    PROJECTION["Polar_Stereographic"],
    PARAMETER["latitude_of_origin",-90],
    PARAMETER["central_meridian",0],
    PARAMETER["scale_factor",1],
    PARAMETER["false_easting",0],
    PARAMETER["false_northing",0],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]]]
Origin = (-383491.061348880291916,410399.872797137824818)
Pixel Size = (17.999204982112094,-17.999204982112094)
Metadata:
  AREA_OR_POINT=Area
Image Structure Metadata:
  COMPRESSION=DEFLATE
  INTERLEAVE=BAND
Corner Coordinates:
Upper Left  ( -383491.061,  410399.873) ( 43d 3'31.36"W, 80d32'41.89"S)
Lower Left  ( -383491.061, -234241.654) (121d25' 1.79"W, 82d25'46.00"S)
Upper Right (  263184.375,  410399.873) ( 32d40'17.59"E, 81d47'18.78"S)
Lower Right (  263184.375, -234241.654) (131d40'12.00"E, 84d 3'39.60"S)
Center      (  -60153.343,   88079.110) ( 34d19'51.59"W, 88d12' 2.26"S)
Band 1 Block=256x256 Type=Byte, ColorInterp=Gray
  Min=2146.000 Max=10112.000
  Minimum=2146.000, Maximum=10112.000, Mean=5382.365, StdDev=1638.523
  NoData Value=0
  Overviews: 17964x17908, 8982x8954, 4491x4477, 2246x2239, 1123x1120,
562x560, 281x280, 141x140, 71x70
  Metadata:
    STATISTICS_MAXIMUM=10112
    STATISTICS_MEAN=5382.3651107267
    STATISTICS_MINIMUM=2146
    STATISTICS_STDDEV=1638.5226548658
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200508/93b8ab72/attachment.html>
