[gdal-dev] Problem building GDAL with Teigha ODA libraries
Paulo Dias Almeida pda at geomaster.pt
Thu May 14 08:02:07 PDT 2020
Thank you Even,
I will follow your advice and report progress.
Regards,
Paulo
Às 10:28 de 14/05/20, Even Rouault escreveu:
> Paulo,
> > I was wondering if you could help with a problem I encountered when
> > building GDAL with the Open Design Alliance Libraries (ODA >= 2021) on
> > Linux.
> Linking against ODA libs is always a pain. What I did to get Windows
> build working is to grep for symbols names in the .lib to find which
> one where exposing the missing symbols that were reported when linking
> GDAL. You could probably do the same on the Linux ODA .so, or use
> objdump -TC on the .so to have the demangled C++ symbols
> When you are doing trial & error, you can directly edit GDALmake.opt
> to speed up the process (instead of patching configure and re-run it)
> For pcre_study, you need -lpcre. But that should normally already be
> in the linking line if libpcre is available (libpcre-dev package on
> Ubuntu)
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Email Signature
Logo <https://www.geomaster.pt>
*Geomaster*
*Paulo Dias Almeida* | Software Engineer
*e:* 	pda at geomaster.pt 	| 	*m:* 	+351 968 248 575
*g:* 	41.54094,-8.40490 	| 	*v: * 	510 906 109
*a: * 	Rua António Cândido Pinto N.º 67, 4715-400 Braga
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200514/da0f7abb/attachment-0001.html>
