[gdal-dev] python code inside of VRT results to empty values
Jachym Cepicky jachym.cepicky at gmail.com
Mon May 25 02:36:47 PDT 2020
Aahaa, the problem was
out_ar[:] = data
while I was using
out_ara = data
Thank you!
Jachym
po 25. 5. 2020 v 11:14 odesílatel Even Rouault
<even.rouault at spatialys.com> napsal:
> On lundi 25 mai 2020 10:44:10 CEST Jachym Cepicky wrote:
> > Hi all,
> > I have some python code inside of VRT file, but I can not produce
> > reasonable output with gdal_transalte. All the input data do look ok,
> > even when I print() the values I would like to store, the data are
> > displayed, but the resulting TIFF file is just empty, any hint how to
> > approach? I've tested it on gdal 2.2 as well as 3.8, so I assume, I do
> > something wrong here. The minimal code looks like
> > import numpy as np
> > import copy
> > def blur(in_ar, out_ar, xoff, yoff, xsize, ysize, raster_xsize,
> > raster_ysize, buf_radius, gt, **kwargs):
> > out_ar = copy.copy(in_ar[0])
> > print(out_ar)
> > return out_ar
> > Any hint?
> Actually, just realizing that you just don't follow the expectations of the
> pixel function. The function should not return an array: it must modify in place
> the provided out_ar argument.
> Like all examples at
> https://gdal.org/drivers/raster/vrt.html#using-derived-bands-with-pixel-functions-in-python
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/pgp/JachymCepicky.pgp
