[gdal-dev] "import gdal" broken in 3.2.0: what to do ?
Kurt Schwehr schwehr at gmail.com
Fri Nov 6 17:49:13 PST 2020
+1 for dropping the old way
On Thu, Nov 5, 2020, 7:59 AM Kai Mühlbauer <kai.muehlbauer at uni-bonn.de>
wrote:
> Hi,
> I'm using GDAL since 2012 and one of the first things I've read is this:
> https://trac.osgeo.org/gdal/wiki/GdalOgrInPython
> The first mention of the deprecation of this import was added 13 years
> ago. To quote from there:
> Additionally, there are five compatibility modules that are included but
> provide notices to state that they are deprecated and will be going
> away. If you are using GDAL 1.5 bindings, you should update your imports
> to utilize the usage above, but the following will work until at least
> GDAL 2.0.
> Not sure, if it's worth the effort to reinstate that behaviour. People
> would have to move on anyway, sooner or later. Just my 2c.
> Huge thanks to Even and all the other people involved with GDAL and
> OSGEO for providing such great tools!
> Cheers,
> Kai
> Am 05.11.20 um 15:39 schrieb Even Rouault:
> > Hi,
> > As noted in https://github.com/OSGeo/gdal/issues/3149, the old way of
> > importing the Python bindings with "import gdal" instead of "from osgeo
> import
> > gdal" was accidentally broken in 3.2.0 . The old way has been officially
> > deprecated for many years.
> > Any opinion if we should just acknowledge that removal by updating 3.2
> NEWS or
> > restore back the old import way (per PR
> https://github.com/OSGeo/gdal/pull/
> > 3150) for 3.2.1 ? (whatever we do, at least people using 3.2.0 would be
> > impacted)
> > Even
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201106/3fb08542/attachment.html>
