[gdal-dev] What is the purpose of -nosrcalpha in gdalwarp?
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Sun Nov 8 08:33:20 PST 2020
I noticed this question from gis.stackexchange https://gis.stackexchange.com/questions/378557/gdalwarp-does-not-use-lanczos-resampling-on-image-with-alpha-channel/378569?noredirect=1#comment618912_378569
It seems that alpha band has some bad effect on the result of lanczos resampling and that can be avoided by using -noscralpha option. From the gdalwarp manual page:
"Prevent the alpha band of a source image to be considered as such (it will be warped as a regular band)".
The option has been added to GDAL version 2.2 but with no mention about any bug that it resolved. What is the difference between warping a band as an alpha band or as a regular band? How users are supposed to know when it is appropriate to use -nosrcalpha switch?
-Jukka Rahkonen-
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201108/b3b55754/attachment.html>
