[gdal-dev] GDAL conda build
Jon Morris Jon.Morris at jbarisk.com
Tue Nov 10 00:12:11 PST 2020
I've been trying to build a Windows conda package for GDAL 3.1.4, but am having problems with the poppler headers. I'm using the conda-forge recipe, which includes a line in the build script to detect the poppler version.
FOR /F "tokens=1,2 delims=." %%a IN ("%poppler%") DO (
  set POPPLER_MAJOR_VERSION=%%a
  set POPPLER_MINOR_VERSION=%%b
https://github.com/conda-forge/gdal-feedstock/commit/320e66064c1288d582a3cadd8b573c863af654d6#diff-6f4a4b77035617ba53fd8a4d15347c44bb89f09d8086a0ffc1a5fca230ae2ed5R16
This doesn't seem to be working, as when we get to compiling the pdf driver, the headers are missing.
(gdal314) %SRC_DIR%\frmts>cd pdf   && nmake /nologo /f makefile.vc   && cd ..   || exit 1
        cl   /nologo /MP4 /MD /EHsc /Ox /FC /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /DNDEBUG /W4 /wd4127 /wd4251 /wd4275 /wd4786 /wd4100 /wd4245 /wd4206 /wd4351 /wd4611  /DHAVE_SSE_AT_COMPILE_TIME /DHAVE_SSSE3_AT_COMPILE_TIME -I..\..\port -I..\..\ogr -I..\..\gcore  -I..\..\alg -I..\..\ogr\ogrsf_frmts  -I..\..\gnm -I..\..\gnm\gnm_frmts -I..\..\apps /DHAVE_AVX_AT_COMPILE_TIME -I..\vrt -I..\mem -I..\..\ogr\ogrsf_frmts\mem  -DPOPPLER_MAJOR_VERSION=0 -DPOPPLER_MINOR_VERSION=23 -DHAVE_POPPLER    -DGNM_ENABLED  -DGDAL_COMPILATION -DNOMINMAX /c pdfdataset.cpp pdfio.cpp pdfobject.cpp pdfcreatecopy.cpp ogrpdflayer.cpp pdfwritabledataset.cpp pdfreadvectors.cpp pdfcreatefromcomposition.cpp
pdfdataset.cpp
pdfio.cpp
pdfobject.cpp
pdfcreatecopy.cpp
c:\bin\anaconda3\conda-bld\gdal_1604943770331\work\frmts\pdf\pdfsdk_headers.h(54): fatal error C1083: Cannot open include file: 'goo/gtypes.h': No such file or directory (compiling source file pdfdataset.cpp)
In pdfsdkheaders.h we can see it's the wrong poppler version that's causing the error:
#if !(POPPLER_MAJOR_VERSION >= 1 || POPPLER_MINOR_VERSION >= 73)
#include <goo/gtypes.h>
#else
typedef unsigned char Guchar;
#endif
The installed version of poppler is 20.11.0, so I don't know why I'm getting major version set to 0 and minor version set to 23.
I'll also ask over at conda as this is most likely a conda build problem, but I thought I would also ask here if anyone has successfully built a conda package and knows how to get this recipe working.
Many thanks!
Jon
Jon Morris
Software Developer
COVID-19. During the current outbreak JBA remains open for business and we continue to deliver our services. However, we have adopted flexible/remote working as required. I will be receiving and reading email as normal but I may not always be available on the office number.
[JBA COVID-19 statement]<https://www.jbagroup.co.uk/sites/www.jbagroup.co.uk/files/documents/15-030%20JBA%20Business%20Continuity%20Briefing%20-%20Latest.pdf>
T +44 (0) 1756 799919
www.jbarisk.com<http://www.jbarisk.com>
[Visit our website]<http://www.jbarisk.com> [http://www.jbagroup.co.uk/imgstore/JBA-Email-Sig-Icons-LINKEDIN.png] <https://www.linkedin.com/in/jon-morris-a2897b4/>  [Follow us on Twitter] <https://twitter.com/jbarisk>
Find out more about us here: www.jbarisk.com<http://www.jbarisk.com/> and follow us on Twitter @JBARisk<http://twitter.com/JBARisk> and LinkedIn<https://www.linkedin.com/company/2370847?trk=tyah&trkInfo=clickedVertical%3Acompany%2CclickedEntityId%3A2370847%2Cidx%3A2-1-2%2CtarId%3A1447414259786%2Ctas%3AJBA%20RISK%20MANAGEMENT>
The JBA Group supports the JBA Trust.
All JBA Risk Management's email messages contain confidential information and are intended only for the individual(s) named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
Please notify the sender immediately by email if you have received this email by mistake and delete this email from your system.
JBA Risk Management Limited is registered in England, company number 07732946, 1 Broughton Park, Old Lane North, Broughton, Skipton, North Yorkshire, BD23 3FD, Telephone: +441756799919
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201110/604b3551/attachment.html>
