[gdal-dev] gdal-dev Digest, Vol 198, Issue 14
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Wed Nov 11 13:55:01 PST 2020
Sorry, this is something that I am not familiar with. The developer of the WCS plugin probably could tell if it is at all supported to use the XML file as input like you tried. I wonder if Ari Jolma happens to follow the list. And what QGIS does is all mystery for me.
-Jukka Rahkonen-
Lähettäjä: 1520 gis <juliermeopensourcedeveloper at gmail.com>
Lähetetty: keskiviikko 11. marraskuuta 2020 16.55
Vastaanottaja: Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi>
Aihe: Re: gdal-dev Digest, Vol 198, Issue 14
Dear Jukka Rahkonen,
Thank you very much for your patience, time, and detailed information given to my questions. I appreciated it all.
In your discussion in [1], I could get the a xml sample [2].
In [3], you will get the whole image available in geoserver. And in [4], You will get the Image [3] subset.
My goal is to load [3] e [4], mainly [4] subset in QGIS, by adding a XML raster. It is important to mention that I am not interested in accessing the raster data through a WCS connection, I am actually adding a xml as a raster (Ctrl + Shift + R).
If you save the xml file in [2] or [5] and add to QGIS as raster data (Ctrl + Shift + R), you will get the image.
Now, the xml you find in [5] was created by just changing the tag values according  to your discussion in [1]. I could not find through gdal documentation how to generate this xml using gdal_translate. GDAL_WMTS driver stunningly does the job. See  gdal_translate "WMTS:http://maps.wien.gv.at/wmts/1.0.0/WMTSCapabilities.xml,layer=lb" wmts.xml -of WMTS.
My need is to create a xml for [4] just like the one available in [5]. I need to access the image in [4] subset using GDAL_WCS.
The command line in [6] creates a tiff image, but I am looking for the xml that when loaded to QGIS ingest the WCS service and loads the image.
I wonder If there is a xml tag to the subset available in [4]. Or if there is a command line for gdal_translate that can generate XML in 3, and most importantly, generate a xml for the subset in [4], similar to gda GDAL_WMTS driver shown above.
Sorry for the long e-mail.  I have no words to thank you for your help and consideration of my messages.
Kinds Regards
Julierme
[1] https://geoserver-users.narkive.com/2FVEaNlm/define-geoserver-bounding-box-using-gdal-s-wcs-driver
[2] XML Sample
<WCS_GDAL>
  <ServiceURL>https://demo.geo-solutions.it/geoserver/wcs?version=2.0.1&</ServiceURL>
  <CoverageName>nurc:mosaic</CoverageName>
  <GetCoverageExtra>&BoundingBox=6.346,36.492,20.83,46.591</GetCoverageExtra>
</WCS_GDAL>
[3]https://demo.geo-solutions.it/geoserver/wcs?Service=WCS
&version=2.0.1
&bbox=-130.85168,20.7052,-62.0054,54.1141
&request=GetCoverage
&coverageId=nurc:Img_Sample
&format=image/png
[4] https://demo.geo-solutions.it/geoserver/wcs?service=WCS
&version=2.0.1
&SubsettingCRS=EPSG:4326
&SUBSET=Long(-100,-80)&SUBSET=Lat(30,40)
&format=image/png
[5] <WCS_GDAL>
  <CoverageName>nurc:Img_Sample</CoverageName>
  <GetCoverageExtra>&BoundingBox=-130.85168,20.7052,-62.0054,54.1141</GetCoverageExtra>
</WCS_GDAL>
[6] gdal_translate -oo CACHE=wcs_cache -oo CLEAR_CACHE -oo INTERLEAVE=PIXEL -projwin 377418 6683393.87938218 377717.879386966 6683094 -oo Subset="time(1985-01-01T00:00:00.000Z)" -outsize 60 0 "WCS:https://beta-karttakuva.maanmittauslaitos.fi/wcs/service/ows?version=2.0.1&coverage=ortokuva__ortokuva" scaled.tiff
On Tue, Nov 10, 2020 at 1:23 PM Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaitos.fi>> wrote:
Sending mail just to you because this is not a proper answer but rather some first-aid. Normally we keep the discussion on the list to other users can help, and get help by the same.
Sorry, -spat is for ogr2ogr, in gdal_translate it is -projwin. Give the bbox coordinates as in the help:
       [-projwin ulx uly lrx lry]
upper left x upper left y lower right x lower right y
Hope that you get it to work but I may look at this deeper when I have better time for that.
First step is to create the XML file. Then test is with gdalinfo, when it reports something that makes sense you can continue with gdal_translate and all the standard options that it has.
WCS 2.0 is pretty easy to use also with plain hand written http requests, read the standard for learning. I would forget older versions.
Test URL for you
https://demo.geo-solutions.it/geoserver/wcs?SERVICE=WCS&REQUEST=GetCoverage&VERSION=2.0.1&CoverageId=nurc__mosaic&subset=Long(8.0,8.1)&subset=Lat(38,38.1)&format=tiff
Unfortunately the server was down earlier today, I hope it works now.
-Jukka-
Lähettäjä: 1520 gis <juliermeopensourcedeveloper at gmail.com<mailto:juliermeopensourcedeveloper at gmail.com>>
Lähetetty: tiistai 10. marraskuuta 2020 18.10
Vastaanottaja: gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>; Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaitos.fi>>
Thank you very much for your reply.
First of all, my apologies for my lack of knowledge about using GDAL_WCS driver. Let me give more details about the issues I am facing.
Extract of http://172.21.14.45:8181/geoserver/ows/wcs?request=GetCapabilities is shown in [1].
Regarding gdal_translate GDAL_WCS driver Image subset extract, looking at https://gdal.org/drivers/raster/wcs.html#examples, I tried the following:
Similar to GDAL_WMTS <gdal_translate "WMTS:http://maps.wien.gv.at/wmts/1.0.0/WMTSCapabilities.xml,layer=lb" wmts.xml -of WMTS>,
I tried running:
(1)
 gdal_translate "WCS:http://172.21.14.45:8181/geoserver/wcs?version=2.0.1&coverage=deter-amazonia__CBERS-4_AWFI_170_111_21052020"  CBERS-4_AWFI_170_111_21052020.xml
The response: I did not get the xml as wmts.xml showed above
Note: Including the -of option (WCS), the outcome fails
(2)
gdal_translate "WCS:http://172.21.14.45:8181/geoserver/ows/wcs?request=GetCapabilities&coverage=deter-amazonia__CBERS-4_AWFI_170_111_21052020" \
-spat -58 -11 -57.75 -10.7 \
The response: There is no -spat option for gdal_translate
gdal_translate --help
Usage: gdal_translate [--help-general] [--long-usage]
       [-ot {Byte/Int16/UInt16/UInt32/Int32/Float32/Float64/
             CInt16/CInt32/CFloat32/CFloat64}] [-strict]
       [-of format] [-b band] [-mask band] [-expand {gray|rgb|rgba}]
       [-outsize xsize[%]|0 ysize[%]|0] [-tr xres yres]
       [-r {nearest,bilinear,cubic,cubicspline,lanczos,average,mode}]
       [-unscale] [-scale[_bn] [src_min src_max [dst_min dst_max]]]* [-exponent[_bn] exp_val]*
       [-srcwin xoff yoff xsize ysize] [-epo] [-eco]
       [-projwin ulx uly lrx lry] [-projwin_srs srs_def]
       [-a_srs srs_def] [-a_ullr ulx uly lrx lry] [-a_nodata value]
       [-a_scale value] [-a_offset value]
       [-nogcp] [-gcp pixel line easting northing [elevation]]*
       |-colorinterp{_bn} {red|green|blue|alpha|gray|undefined}]
       |-colorinterp {red|green|blue|alpha|gray|undefined},...]
       [-mo "META-TAG=VALUE"]* [-q] [-sds]
       [-co "NAME=VALUE"]* [-stats] [-norat]
       [-oo NAME=VALUE]*
       src_dataset dst_dataset
[1] WCS GetCapabilities request
<wcs:CoverageSummary>
<ows:Title>CBERS-4_AWFI_170_111_21052020</ows:Title>
<ows:Abstract>Generated from GeoTIFF</ows:Abstract>
<ows:Keywords>
<ows:Keyword>deter-amazonia-CBERS-4_AWFI_170_111_21052020</ows:Keyword>
<ows:Keyword>WCS</ows:Keyword>
<ows:Keyword>GeoTIFF</ows:Keyword>
</ows:Keywords>
<wcs:CoverageId>deter-amazonia__CBERS-4_AWFI_170_111_21052020</wcs:CoverageId>
<wcs:CoverageSubtype>RectifiedGridCoverage</wcs:CoverageSubtype>
<ows:WGS84BoundingBox>
<ows:LowerCorner>-63.280290728152664 -13.794296142085976</ows:LowerCorner>
<ows:UpperCorner>-53.624004749255874 -5.636644661059637</ows:UpperCorner>
</ows:WGS84BoundingBox>
<ows:BoundingBox crs="http://www.opengis.net/def/crs/EPSG/0/EPSG:4326">
</ows:BoundingBox>
</wcs:CoverageSummary>
Any comment will be very appreciated.
GDAL website<https://gdal.org/drivers/raster/wmts.html> provides examples on how to run GDAL_WMTS driver in order to get a wmts xml file. I have looked in https://gdal.org/drivers/raster/wcs.html and could not find an example pointing to -spat option.  I got an -spat option
to gdal_grid<https://gdal.org/programs/gdal_grid.html?highlight=spat#cmdoption-gdal_grid-spat> though.
gdal_translate "WCS:http://www.dpi.inpe.br/fipcerrado-geoserver/ows/wcs?request=GetCapabilities" \
-oo CoverageName=deter-cerrado:CBERS-4_AWFI_161_099_13072018 CBERS-4_AWFI_161_099_13072018.xml -of WCS
On Mon, Nov 9, 2020 at 5:00 PM <gdal-dev-request at lists.osgeo.org<mailto:gdal-dev-request at lists.osgeo.org>> wrote:
Send gdal-dev mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
        https://lists.osgeo.org/mailman/listinfo/gdal-dev
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
        gdal-dev-owner at lists.osgeo.org<mailto:gdal-dev-owner at lists.osgeo.org>
When replying, please edit your Subject line so it is more specific
than "Re: Contents of gdal-dev digest..."
Today's Topics:
   1. Re: Selecting just the geometry column with OGR SQL (Even Rouault)
   2. Re: Selecting just the geometry column with OGR SQL
      (Rahkonen Jukka (MML))
   3. Re: WCS_GDAL Driver Image SubSet Request (jratike80)
Message: 1
Date: Mon, 09 Nov 2020 16:09:45 +0100
From: Even Rouault <even.rouault at spatialys.com<mailto:even.rouault at spatialys.com>>
To: gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
Cc: "Rahkonen Jukka (MML)" <jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaitos.fi>>
Subject: Re: [gdal-dev] Selecting just the geometry column with OGR
        SQL
Message-ID: <1659214.2tRo4lr4Oo at even-i700<mailto:1659214.2tRo4lr4Oo at even-i700>>
Content-Type: text/plain; charset="us-ascii"
Jukka,
> I believe that OGR SQL dialect adds the geometry column into SQL selection
> by default. Am I right with this? I volunteer to edit the documentation
> https://gdal.org/user/ogr_sql_dialect.html if this is the case. But what I
> can't understand is another side of the story, how to select just the
> geometry field with OGR SQL dialect from some data sources.
> This command returns both time column and geometry from GML
> ogrinfo -sql "select time from timetest" timetest.gml
> I can select just the geometry from geometry column named as
> "geometryProperty" by ogrinfo -sql "select geometryProperty from timetest"
> timetest.gml
> The behavior is the same with SpatiaLite when I use "-dialect OGRSQL".
> Geometry is selected automatically but it can be selected also by name. But
> I cannot discover any way to select just the geometry field from shapefile.
> Is it because geometry column in shapefile does not have any name as this
> Python test seems to prove?
> >>> from osgeo import ogr
> >>> shp_ds = ogr.Open('timetest.shp')
> >>> shp_lyr = shp_ds.GetLayer(0)
> >>> shp_lyr.GetGeometryColumn()
> OpenJUMP JML driver does not report a name for geometry column either. Is it
> rather an exception that drivers give names for the geometry columns? I
> know I can select only the geometry column with the SQLite dialect, but I
> am curious.
Indeed, in OGR SQL, if the geometry column has a non-empty name (typically for
database drivers), you can use it to select it. When the geometry column name
is empty, such as in the shapefile or OpenJUMP driver, you can use
_ogr_geometry_ (with leading and trainling underscore) to select it. This is
likely undocumented.
As far as I can see, this was introduced per
https://github.com/OSGeo/gdal/commit/1519dcb00bd7802d2f701114f0e1cb9b524a547f
to fix an issue with comparison with empty string literals (this was before
OGR enforced the difference between single-quoted string literals and double-
quoted identifiers)
Even
http://www.spatialys.com
Message: 2
Date: Mon, 9 Nov 2020 15:35:11 +0000
From: "Rahkonen Jukka (MML)" <jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaitos.fi>>
To: Even Rouault <even.rouault at spatialys.com<mailto:even.rouault at spatialys.com>>,
        "gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>" <gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>>
        SQL
Message-ID: <d59795ddfd994dee9f5eca836361324a at maanmittauslaitos.fi<mailto:d59795ddfd994dee9f5eca836361324a at maanmittauslaitos.fi>>
Even Rouault wrote:
maanantai 9. marraskuuta 2020 17.10
> Jukka,
>> selection by default. Am I right with this? I volunteer to edit the
>> documentation https://gdal.org/user/ogr_sql_dialect.html if this is
>> the case. But what I can't understand is another side of the story,
>> how to select just the geometry field with OGR SQL dialect from some data sources.
>> This command returns both time column and geometry from GML ogrinfo
>> -sql "select time from timetest" timetest.gml I can select just the
>> geometry from geometry column named as "geometryProperty" by ogrinfo
>> timetest.gml
>> name. But I cannot discover any way to select just the geometry field from shapefile.
>> this Python test seems to prove?
>> Is it rather an exception that drivers give names for the geometry
>> columns? I know I can select only the geometry column with the SQLite
>> dialect, but I am curious.
> Indeed, in OGR SQL, if the geometry column has a nonempty name (typically for
> _ogr_geometry_ (with leading and trainling underscore) to select it. This is likely undocumented.
> to fix an issue with comparison with empty string literals (this was before OGR enforced the
>  difference between single-quoted string literals and double- quoted identifiers)
I could not manage to guess the right syntax for Windows right ahead but solved the quiz easily
with your double-quote hint
First trial:
ogrinfo -sql "select _ogr_geometry_ from timetest" timetest.shp
INFO: Open of `timetest.shp'
      using driver `ESRI Shapefile' successful.
ERROR 1: SQL Expression Parsing Error: syntax error, unexpected $undefined. Occurred around :
Second trial:
ogrinfo -sql "select \"_ogr_geometry_\" from timetest" timetest.shp
-Jukka-
> Even
Spatialys - Geospatial professional services http://www.spatialys.com
Message: 3
Date: Mon, 9 Nov 2020 08:47:05 -0700 (MST)
From: jratike80 <jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaitos.fi>>
Subject: Re: [gdal-dev] WCS_GDAL Driver Image SubSet Request
Message-ID: <1604936825138-0.post at n6.nabble.com<mailto:1604936825138-0.post at n6.nabble.com>>
Content-Type: text/plain; charset=us-ascii
Do you want to make is somehow impossible to request data beyound the
BoundingBox that you defined in the XML file? If you just want to get data
from the rectangle that you or your users define, gdal_translate with the
regular -spat option should work out-of-the-box.
-Jukka Rahkonen-
juliermeopensourcedeveloper wrote
> Hi all,
> Is it possible to define a bounding box in order to request a coverage
> subset using the GDAL WCS Driver?
> I have tried the code in [1]. I  am trying to get information only for the
> bbox_interest=( -58,-11,-57.75,-10.75) as shown below, however the subset
> image or bbox_interest request has not been delivered. The West Longitude
> reaches -50.17 and The Lower Latitude reaches -18.92 which are limits out
> of the bbox_interest.
> The image extent is:
> <GetCoverageExtra>
> &BoundingBox=-63.280290728152664,-13.794296142085976,-53.624004749255874,-5.636644661059637
> </GetCoverageExtra>
>  Any comment on this issue will be greatly appreciated.
> Thank you very much for your time in advance.
> *CODE [1]:*
> <WCS_GDAL>
> <ServiceURL>
> http://172.21.14.45:6060/geoserver/wcs?version=1.0.0&
> ServiceURL>
> <CoverageName>
> cbers_deter_amazonia:CBERS-4_AWFI_170_111_21052020
> CoverageName>
> <GetCoverageExtra>
> &BoundingBox=-58,-11,-57.75,-10.75
> </GetCoverageExtra>
> <CoverageOffering>
> <description>
> </description>
> <name>
> </name>
> <label>
> </label>
> <lonLatEnvelope srsName="urn:ogc:def:crs:OGC:1.3:CRS84">
> <pos>
> -58 -11
> </pos>
> <pos>
> -57.75 -10.75
> </pos>
> </lonLatEnvelope>
> <keywords>
> <keyword>
> WCS
> </keyword>
> <keyword>
> GeoTIFF
> </keyword>
> </keywords>
> <domainSet>
> <spatialDomain>
> <Envelope srsName="EPSG:4326">
> <pos>
> -58 -11
> </pos>
> <pos>
> -57.75 -10.75
> </pos>
> </Envelope>
> <RectifiedGrid dimension="2" srsName="EPSG:4326">
> <limits>
> <GridEnvelope>
> <low>
> 0 0
> </low>
> <high>
> 0 0
> </high>
> </GridEnvelope>
> </limits>
> <axisName>
> x
> </axisName>
> <axisName>
> y
> </axisName>
> <origin>
> <pos>
> -58 -10.75
> </pos>
> </origin>
> <offsetVector>
> 0.005364603321609328 0.0
> </offsetVector>
> <offsetVector>
> 0.0 -0.004532028600570188
> </offsetVector>
> </RectifiedGrid>
> </spatialDomain>
> </domainSet>
> <rangeSet>
> <RangeSet>
> <name>
> </name>
> <label>
> </label>
> <axisDescription>
> <AxisDescription>
> <name>
> Band
> </name>
> <label>
> Band
> </label>
> <values>
> <interval>
> <min>
> 1
> </min>
> <max>
> 4
> </max>
> </interval>
> </values>
> </AxisDescription>
> </axisDescription>
> </RangeSet>
> </rangeSet>
> <supportedCRSs>
> <requestResponseCRSs>
> EPSG:4326
> </requestResponseCRSs>
> </supportedCRSs>
> <supportedFormats nativeFormat="GeoTIFF">
> <formats>
> GeoTIFF
> </formats>
> <formats>
> GIF
> </formats>
> <formats>
> JPEG
> </formats>
> <formats>
> PNG
> </formats>
> <formats>
> TIFF
> </formats>
> </supportedFormats>
> <supportedInterpolations default="nearest neighbor">
> <interpolationMethod>
> nearest neighbor
> </interpolationMethod>
> bilinear
> bicubic
> </supportedInterpolations>
> </CoverageOffering>
> <PreferredFormat>
> GeoTIFF
> </PreferredFormat>
> <BandCount>
> 4
> </BandCount>
> <BandType>
> Byte
> </BandType>
> </WCS_GDAL>
> gdal-dev at .osgeo<mailto:gdal-dev at .osgeo>
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
Subject: Digest Footer
End of gdal-dev Digest, Vol 198, Issue 14
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201111/dbefba9b/attachment-0001.html>
