[gdal-dev] gdalwarp from EPSG:25832 to EPSG:4326 with error latitude or longitude exceeded limits?
jratike80 jukka.rahkonen at maanmittauslaitos.fi
Wed Nov 25 03:05:18 PST 2020
Hi again,
Sorry, I did not read properly what you did. That should work and it does
work for me with GDAL 3.2. I use a copy of your test.tif as "test_00.tif".
gdal_translate -a_srs epsg:4647 test_00.tif test_000.tif
Input file size is 100, 100
0...10...20...30...40...50...60...70...80...90...100 - done.
gdalwarp -t_srs epsg:4326 test_000.tif test_4326_2.tif
Creating output file that is 125P x 73L.
Processing test_000.tif [1/1] : 0Using internal nodata values (e.g. -9999)
for image test_000.tif.
Copying nodata values from source test_000.tif to destination
test_4326_2.tif.
-Jukka-
jratike80 wrote
> Hi,
> What you have wrong is the input coordinate system, not the output as you
> tested.
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
