[gdal-dev] GetProjection returns empty string, python 3.7
Paul Harwood runette at gmail.com
Mon Oct 26 15:31:14 PDT 2020
Me too.
But which conda package for gdal are you using - there are a lot of ones
out there.
Are you using conda install -c conda-forge gdal ?
It should be version 3.1.4 at the moment ?
Also - I don't know if this is part of it but ...
"srs = osr.SpatialReference()
srs.SetUTM(11, 1)
srs.SetWellKnownGeogCS("NAD27")
dst_ds.SetProjection(srs.ExportToWkt())
why not just
srs.SetUTM(11, 1)
dst_ds.SetSpatialRef(srs)
On Mon, 26 Oct 2020 at 22:11, Nicolas Cadieux <njacadieux.gitlab at gmail.com>
wrote:
> Hi,
> Comes back as None for me... :(  I'am working with Anaconda.  Could it be
> my environment?
> Nicolas
> On 2020-10-26 5:04 p.m., Paul Harwood wrote:
> GetSpatialRef is OSR based and it is certainly working for me against GDAL
> Raster datasets - it would not be a method against the GDAL Dataset if it
> was only an OGR thing - OGR has its own objects.
> This code is working for me at this very minute and giving me the name of
> the CRS for a gtiff
> dataset = gdal.Open(str(filepath))
>         if dataset:
>             proj = "None"
>             crs = dataset.GetSpatialRef()
>             if crs:
>                 proj = crs.GetName()
>             return {"type": "gdal", "driver":
> dataset.GetDriver().ShortName, "proj": proj}
> On Mon, 26 Oct 2020 at 20:08, Nicolas Cadieux <njacadieux.gitlab at gmail.com>
> wrote:
>> Hi,
>> Thanks for helping.  I will put my code at the end.  The problem seems to
>> be between gdal python lib 2.2.2 and 3.0.2.  Under 2.2.2 and < 3,
>> GetProjection() works well but return nothing with gdal python lib 3.0.2.
>> It's my understanding that .GetSpatialRef is for OGR data (vector).  Am I
>> wrong?
>> I was using GetProjection() because that is the method used in the
>> raster_api tutorial.  (https://gdal.org/tutorials/raster_api_tut.html)
>> I understand that gdal 3 now relies on proj 6 for the SpatialRef.  I'am
>> trying to figure out if is a problem with proj or with gdal...
>> Nicolas
>> code:
>> # -*- coding: utf-8 -*-
>> Created on Sun Oct 25 15:09:05 2020
>> @author: Nicolas
>> https://stackoverflow.com/questions/37648439/simplest-way-to-save-array-into-raster-file-in-python
>> from osgeo import gdal, osr, ogr
>> import numpy
>> print (gdal.__version__)
>> # https://gdal.org/tutorials/raster_api_tut.html
>> fileformat = "GTiff"
>> driver = gdal.GetDriverByName(fileformat)
>> metadata = driver.GetMetadata()
>> if metadata.get(gdal.DCAP_CREATE) == "YES":
>>     print("Driver {} supports Create() method.".format(fileformat))
>> if metadata.get(gdal.DCAP_CREATECOPY) == "YES":
>>     print("Driver {} supports CreateCopy() method.".format(fileformat))
>> dst_ds = driver.Create(r"c:\temp\gdal.tif", xsize=512, ysize=512,
>>                     bands=1, eType=gdal.GDT_Byte)
>> dst_ds.SetGeoTransform([444720, 30, 0, 3751320, 0, -30])
>> srs.SetUTM(11, 1)
>> print ('srs = ',srs)# this is good
>> raster = numpy.zeros((512, 512), dtype=numpy.uint8)
>> dst_ds.GetRasterBand(1).WriteArray(raster)
>> # Once we're done, close properly the dataset
>> srs = None
>> dst_ds = None #srs is file and well georeferenced in Qgis.
>> # open dataset try to read srs
>> raster_ds = gdal.Open(r"C:\temp\gdal.tif")
>> # first try
>> print("Projection is {}".format(raster_ds.GetProjection()))
>> # second try
>> srs.ImportFromWkt(raster_ds.GetProjectionRef())
>> print ('srs =', srs)
>> # thrid try
>> srs = raster_ds.GetProjection()
>> print('srs =', srs)
>> srs = raster_ds.GetProjectionRef()
>> # forth try
>> # from gdal_info
>> https://github.com/OSGeo/gdal/blob/master/gdal/swig/python/samples/gdalinfo.py
>> pszProjection = raster_ds.GetProjectionRef()
>> print(pszProjection)
>> if pszProjection is not None:
>>     hSRS = osr.SpatialReference()
>>     if hSRS.ImportFromWkt(pszProjection) == gdal.CE_None:
>>         pszPrettyWkt = hSRS.ExportToPrettyWkt(False)
>>         print("Coordinate System is:\n%s" % pszPrettyWkt)
>>     else:
>>         print("Coordinate System is `%s'" % pszProjection)
>> On 2020-10-26 3:44 p.m., Paul Harwood wrote:
>> I am not sure why you are using GetProjection and not GetSpatialRef ?
>> Although, the code snippet you included in your email does not seem to use
>> either?
>> I certainly was in the process of working on some code that uses
>> .GeoSptialRef very successfully on GDAL3.1.3 - so I am sure that it is
>> working!
>> On Mon, 26 Oct 2020 at 18:36, Nicolas Cadieux <
>> njacadieux.gitlab at gmail.com> wrote:
>>> New info!
>>> GetProjection works with gdal python 2.2.2 and 2.3.3 but not with with
>>> gdal 3.0.2.  Is this a change in the gdal library?
>>> Nicolas
>>> On 2020-10-26 1:53 p.m., Nicolas Cadieux wrote:
>>> > Hi,
>>> > In case mail question was not clear, I have posted the questions about
>>> > this on stackexchange.  I posted a full code that you can run exposing
>>> > my problem and question.
>>> > Thanks
>>> > Nicolas
>>> https://gis.stackexchange.com/questions/377567/cannot-get-projection-from-raster-dataset-using-getprojection
>>> > On 2020-10-25 9:31 p.m., Nicolas Cadieux wrote:
>>> >> Hi,
>>> >> With the following code, I get an empty string indicating the
>>> >> projection is not valid.
>>> >> raster_ds = gdal.Open(r"C:\temp\180922_WTE3.tif")
>>> >> target_ds =
>>> driver.Create(r"c:\temp\output.tif",xsize=raster_ds_ncol,ysize=raster_ds_nrow,bands
>>> >> = 1,eType = gdal.GDT_Float32)
>>> >> (array is a numpty array.)
>>> >> raster_srs = osr.SpatialReference()
>>> >> raster_srs.ImportFromWkt(raster_ds.GetProjectionRef())
>>> >> target_ds.SetProjection(raster_srs.ExportToWkt())
>>> >> target_ds.GetRasterBand(1).WriteArray(array)
>>> >> raster_ds = None #close dataset
>>> >> target_ds=None
>>> >> Below is the result of gdal info from qgis. File appears to have a
>>> >> valid projection and is properly georeferenced in QGIS using other
>>> >> data sets.   Is this projection wrong or am I missing something in my
>>> >> python code?  The goal is to extract the projection from raster_ds
>>> >> set in order to apply to target_ds.  I can create the file, apply a
>>> >> geotransform but can't get the projection.  Can you help?
>>> >> Thanks/merci!
>>> >> Nicolas
>>> >> QGIS version: 3.14.16-Pi
>>> >> QGIS code revision: df27394552
>>> >> Qt version: 5.11.2
>>> >> GDAL version: 3.0.4
>>> >> GEOS version: 3.8.1-CAPI-1.13.3
>>> >> PROJ version: Rel. 6.3.2, May 1st, 2020
>>> >> Processing algorithm…
>>> >> Algorithm 'Raster information' starting…
>>> >> Input parameters:
>>> >> { 'EXTRA' : '', 'INPUT' : 'C:/temp/180922_WTE3.tif', 'MIN_MAX' :
>>> >> False, 'NOGCP' : False, 'NO_METADATA' : False, 'OUTPUT' :
>>> >> 'TEMPORARY_OUTPUT', 'STATS' : False }
>>> >> GDAL command:
>>> >> gdalinfo C:/temp/180922_WTE3.tif
>>> >> GDAL command output:
>>> >> Warning 1: TIFFReadDirectory:Sum of Photometric type-related color
>>> >> channels and ExtraSamples doesn't match SamplesPerPixel. Defining
>>> >> non-color channels as ExtraSamples.
>>> >> Driver: GTiff/GeoTIFF
>>> >> Files: C:/temp/180922_WTE3.tif
>>> >> Size is 1194, 2783
>>> >> PROJCRS["WGS 84 / UTM zone 18N",
>>> >> BASEGEOGCRS["WGS 84",
>>> >> DATUM["World Geodetic System 1984",
>>> >> ELLIPSOID["WGS 84",6378137,298.257223563,
>>> >> LENGTHUNIT["metre",1]]],
>>> >> PRIMEM["Greenwich",0,
>>> >> ANGLEUNIT["degree",0.0174532925199433]],
>>> >> ID["EPSG",4326]],
>>> >> CONVERSION["UTM zone 18N",
>>> >> METHOD["Transverse Mercator",
>>> >> ID["EPSG",9807]],
>>> >> PARAMETER["Latitude of natural origin",0,
>>> >> ANGLEUNIT["degree",0.0174532925199433],
>>> >> ID["EPSG",8801]],
>>> >> PARAMETER["Longitude of natural origin",-75,
>>> >> ID["EPSG",8802]],
>>> >> PARAMETER["Scale factor at natural origin",0.9996,
>>> >> SCALEUNIT["unity",1],
>>> >> ID["EPSG",8805]],
>>> >> PARAMETER["False easting",500000,
>>> >> LENGTHUNIT["metre",1],
>>> >> ID["EPSG",8806]],
>>> >> PARAMETER["False northing",0,
>>> >> ID["EPSG",8807]]],
>>> >> CS[Cartesian,2],
>>> >> AXIS["(E)",east,
>>> >> ORDER[1],
>>> >> LENGTHUNIT["metre",1]],
>>> >> AXIS["(N)",north,
>>> >> ORDER[2],
>>> >> USAGE[
>>> >> SCOPE["unknown"],
>>> >> AREA["World - N hemisphere - 78°W to 72°W - by country"],
>>> >> BBOX[0,-78,84,-72]],
>>> >> ID["EPSG",32618]]
>>> >> Data axis to CRS axis mapping: 1,2
>>> >> Origin = (459417.200000000011642,5028584.700000000186265)
>>> >> Pixel Size = (0.050000000000000,-0.050000000000000)
>>> >> Metadata:
>>> >> AREA_OR_POINT=Area
>>> >> TIFFTAG_XRESOLUTION=1
>>> >> TIFFTAG_YRESOLUTION=1
>>> >> Image Structure Metadata:
>>> >> INTERLEAVE=BAND
>>> >> Corner Coordinates:
>>> >> Upper Left ( 459417.200, 5028584.700) ( 75d31' 7.03"W, 45d24'34.58"N)
>>> >> Lower Left ( 459417.200, 5028445.550) ( 75d31' 6.99"W, 45d24'30.07"N)
>>> >> Upper Right ( 459476.900, 5028584.700) ( 75d31' 4.28"W, 45d24'34.59"N)
>>> >> Lower Right ( 459476.900, 5028445.550) ( 75d31' 4.24"W, 45d24'30.08"N)
>>> >> Center ( 459447.050, 5028515.125) ( 75d31' 5.63"W, 45d24'32.33"N)
>>> >> Band 1 Block=1194x1 Type=UInt16, ColorInterp=Red
>>> >> Band 288 Block=1194x1 Type=UInt16, ColorInterp=Undefined
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201026/e0b80c5a/attachment-0001.html>
