[gdal-dev] What to archiv when using gdal_translate -co TILED=YES
APM apschwimmer at apmland.de
Thu Sep 24 09:56:07 PDT 2020
Dear all,
I want to create a geotiff which has 2GB size at the end.
Further I used the option -co TILED=YES and the compression LZW.
Unfortunately a program breaks after opening the map.
Qgis need some time, but show the map.
What does Tiled=YES?
Should it "break" the file in 'handsome" segments to make it loadable in
the pc ram similar to tiles in web services?
Make it sense to add a block size?
Can I change the file to another tif format and compress it with jpeg?
gdalinfo for a .vrt which I like to compress:
Coordinate System is:
PROJCRS["ETRS89 / UTM zone 32N",
     BASEGEOGCRS["ETRS89",
         DATUM["European Terrestrial Reference System 1989",
             ELLIPSOID["GRS 1980",6378137,298.257222101,
                 LENGTHUNIT["metre",1]]],
Band 1 Block=128x128 Type=Byte, ColorInterp=Palette
   Color Table (RGB with 256 entries)
     0: 255,255,255,255
     1: 255,255,255,255
     2: 255,255,255,255
     3: 191,230,230,255
     4: 153,255,179,255
     5: 230,255,204,255
     6: 191,242,128,255
Thank you very much for your help!
Kind regard
Piet
