[gdal-dev] Shall I continue trying to get gdal java bindings to work?
paul.malm at lfv.se paul.malm at lfv.se
Tue Apr 6 22:17:15 PDT 2021
When I copy ALL the dll-files in gdal\bin (geos.dll, geos_c.dll etc.) to my java-jre\bin folder (where I also copied the gdalalljni.dll) it seems to work. Couldn't this be added in the installation instructions some were?
Kind regards,
Paul
Från: Malm, Paul (Operations AIM)
Skickat: den 6 april 2021 10:42
Till: 'gdal-dev at lists.osgeo.org' <gdal-dev at lists.osgeo.org>
Ämne: Shall I continue trying to get gdal java bindings to work?
is it possible to get Gdal java bindings to work in Windows 10? If not to whom do I report the error?
I've downloaded release-1928-x64-gdal-3-2-1-mapserver-7-6-2.zip
and can't get gdalalljni.dll to load. I've tried to get help from here and from the them creating the zip -file. But without any luck.
I just want to know if it is possible at all, since I've tried to get it to work for four weeks now.
Has anyone at all got gdalalljni.dll to load?
Kind regards,
Paul
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210407/0427ac0a/attachment.html>
