[gdal-dev] NITF Int16 image size limit
Even Rouault even.rouault at spatialys.com
Wed Apr 7 06:41:22 PDT 2021
Hum, 4294967295 = 0xffffffff = max uint32 value. This really a
suspicious file size that looks like truncation at the 4 GB limit. Are
you really really sure that you tested the non-GDAL implementation with
that exact file, and not another version that might have been truncated
later ?
Le 07/04/2021 à 14:59, ni hao a écrit :
> Hi Even,
> I am using GDAL 2.4.4. I may try the latest version as you suggested.
> The NITF file size is 4,294,967,295 bytes
> The vendor used a non-GDAL implementation, and was able to display all
> image.
> Metadata:
>   NITF_ABPP=16
>   NITF_BLOCKA_BLOCK_COUNT=01
>   NITF_BLOCKA_BLOCK_INSTANCE_01=01
>   NITF_BLOCKA_FRFC_LOC_01=
>   NITF_BLOCKA_FRLC_LOC_01=
>   NITF_BLOCKA_LAYOVER_ANGLE_01=000
>   NITF_BLOCKA_LRFC_LOC_01=
>   NITF_BLOCKA_LRLC_LOC_01=
>   NITF_BLOCKA_L_LINES_01=19694
>   NITF_BLOCKA_N_GRAY_01=00000
>   NITF_BLOCKA_SHADOW_ANGLE_01=180
>   NITF_CCS_COLUMN=0
>   NITF_CCS_ROW=0
>   NITF_CLEVEL=07
>   NITF_ENCRYP=0
>   NITF_FBKGC=  0,  0,  0
>   NITF_FDT=
>   NITF_FHDR=NITF02.10
>   NITF_FSCATP=
>   NITF_FSCAUT=
>   NITF_FSCLAS=U
>   NITF_FSCLSY=CA
>   NITF_FSCLTX=
>   NITF_FSCODE=
>   NITF_FSCOP=00000
>   NITF_FSCPYS=00000
>   NITF_FSCRSN=
>   NITF_FSCTLH=
>   NITF_FSCTLN=
>   NITF_FSDCDT=
>   NITF_FSDCTP=
>   NITF_FSDCXM=
>   NITF_FSDG=
>   NITF_FSDGDT=
>   NITF_FSREL=
>   NITF_FSSRDT=
>   NITF_FTITLE=
>   NITF_IALVL=0
>   NITF_IC=NC
>   NITF_ICAT=SAR
>   NITF_ICORDS=G
>   NITF_IDATIM=
>   NITF_IDLVL=
>   NITF_IGEOLO=
>   NITF_IID1=P1
>   NITF_IID2=
>   NITF_ILOC_COLUMN=0
>   NITF_ILOC_ROW=0
>   NITF_IMAG=1.0
>   NITF_IMODE=P
>   NITF_IREP=MULTI
>   NITF_ISCATP=
>   NITF_ISCAUT=
>   NITF_ISCLAS=U
>   NITF_ISCLSY=CA
>   NITF_ISCLTX=
>   NITF_ISCODE=
>   NITF_ISCRSN=
>   NITF_ISCTLH=
>   NITF_ISCTLN=
>   NITF_ISDCDT=
>   NITF_ISDCTP=
>   NITF_ISDCXM=
>   NITF_ISDG=
>   NITF_ISDGDT=
>   NITF_ISORCE=
>   NITF_ISREL=
>   NITF_ISSRDT=
>   NITF_ONAME=
>   NITF_OPHONE=
>   NITF_OSTAID=CSA
>   NITF_PJUST=R
>   NITF_PVTYPE=INT
>   NITF_STYPE=BF01
>   NITF_TGTID=
> *From:* Even Rouault <even.rouault at spatialys.com>
> *Sent:* April 7, 2021 5:23 AM
> *To:* ni hao <ni_hao88 at hotmail.com>; gdal-dev at lists.osgeo.org
> <gdal-dev at lists.osgeo.org>
> *Subject:* Re: [gdal-dev] NITF Int16 image size limit
> Hi,
> Actually the error message doesn't look like there's a uint32 overflow
> as it displays a file offset that is beyond the 4 GB limit.
> Did you check that your file size is at least 4324329780 + 4194302 = 4
> 328 524 082 bytes ? I guess it is not, or then there's some mysterious
> error in the low level GDAL I/O layer.
> So if your file is smaller than that,
> - either it is corrupted (would be good if you could check that with a
> non-GDAL implementation)
> - or there's a bug in the NITF driver in how it computes offsets.
> Could you report the values of the NITF_ABPP, NITF_IC and NITF_IMODE
> metadata reported by gdalinfo ?
> Even
> Le 07/04/2021 à 02:09, ni hao a écrit :
>> gdalinfo output i:
>> Driver: NITF/National Imagery Transmission Format
>> Files: ##CH_CV_GRD\imagery\12499.ntf
>> Size is 61180, 19694
>> Coordinate System is `'
>> GCP Projection =
>> GEOGCS["WGS 84",   ... ]
>> Band 1 Block=1024x1024 Type=UInt16, ColorInterp=Gray
>> Band 2 Block=1024x1024 Type=UInt16, ColorInterp=Gray
>> Also I am sure it is the UInt16 overflow, as the message is:
>> ERROR 3: Unable to read 4194302 byte block from 4324329780
>> and 2**32 = 4294967296
>> *From:* bradh at frogmouth.net <mailto:bradh at frogmouth.net>
>> <bradh at frogmouth.net> <mailto:bradh at frogmouth.net>
>> *Sent:* April 6, 2021 8:17 PM
>> *To:* Even Rouault <even.rouault at spatialys.com>
>> <mailto:even.rouault at spatialys.com>; ni hao <ni_hao88 at hotmail.com>
>> <mailto:ni_hao88 at hotmail.com>
>> *Cc:* gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>> <gdal-dev at lists.osgeo.org> <mailto:gdal-dev at lists.osgeo.org>
>> Also if you can show the headers (e.g. from gdalinfo), that might
>> provide indication of exactly which value is the issue.
>> Brad
>> On 7 Apr. 2021 04:00, Even Rouault <even.rouault at spatialys.com>
>> <mailto:even.rouault at spatialys.com> wrote:
>>     Please keep the mailing list copied (I re-added it)
>>     This is not the most recent one (3.2.2 is), but skimming quickly
>>     through release notes, I can't see anything directly related, so
>>     it might still be current with the recent versions. Altough I see
>>     that a bunch of "avoid unsigned integer overflow" type of fixes
>>     have been done since 2.4, so some of them might have accidentally
>>     fixed the issue.
>>     If you can try with the latest version ( Docker images mentioned
>>     at https://github.com/OSGeo/gdal/tree/master/gdal/docker
>>     <https://github.com/OSGeo/gdal/tree/master/gdal/docker>, Conda,
>>     etc .), that could be interesting.
>>     Le 06/04/2021 à 19:51, ni hao a écrit :
>>         Hi Even,
>>         The version is 2.4.4.
>>         *Sent:* April 6, 2021 2:46 PM
>>         <mailto:ni_hao88 at hotmail.com>; gdal-dev at lists.osgeo.org
>>         <mailto:gdal-dev at lists.osgeo.org> <gdal-dev at lists.osgeo.org>
>>         Shawn,
>>         This sounds more like a unwanted integer overflow somewhere
>>         in the NITF driver.  Is this with a recent GDAL ? If so,
>>         please file a bug at https://github.com/OSGeo/gdal/issues/new
>>         <https://github.com/OSGeo/gdal/issues/new> with all the
>>         details needed. A link to the dataset would be ideal, but
>>         otherwise please provide in the ticket description the output
>>         of "gdalinfo your.nitf"
>>         Even
>>         Le 06/04/2021 à 19:35, ni hao a écrit :
>>             Hi list,
>>             I encountered problem ingesting a large NITF Int16 image
>>             with GDAL:
>>             NITF 2-band image in Int16 format, 4.3 GB. It has 19690
>>             lines x 61180 pixels.  The upper 90% of the image looks
>>             fine.  But the last 2000 lines fail to load by GDAL.
>>              That coincides with the 32-bit boundary.
>>             Note that another larger NITF in 32-bit float, 10.1 GB
>>             file loads fine.
>>             Is there a hard limit on NITF Int16 file size?
>>             Thanks,
>>             Shawn
>>             _______________________________________________
>>             gdal-dev mailing list
>>             https://lists.osgeo.org/mailman/listinfo/gdal-dev  <https://lists.osgeo.org/mailman/listinfo/gdal-dev>
>>         http://www.spatialys.com  <http://www.spatialys.com>
>>         My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210407/8b9a6862/attachment-0001.html>
