[gdal-dev] Python create BigTIFF image
Even Rouault even.rouault at spatialys.com
Tue Apr 20 11:56:53 PDT 2021
Le 20/04/2021 à 20:53, ni hao a écrit :
> Hi list,
> I use Python to create GeoTiff image, and I get the error because it
> exceeds 4GB.
> ds = gdal.GetDriverByName('GTiff').Create(output_magnitude, xsize,
> ysize, 1, gdal.GDT_Float32)
>    ERROR 1: TIFFReadDirectory:Failed to read directory at offset
> 4294957836
>    ERROR 1: TIFFWriteDirectoryTagData:Maximum TIFF file size exceeded.
> Use BIGTIFF=YES creation option.
> I need to turn on *BIGTIFF=YES*
> https://gdal.org/drivers/raster/gtiff.html
> <https://gdal.org/drivers/raster/gtiff.html>
> But I don't do know how. I tried:
> ysize, 1, gdal.GDT_Float32, BIGTIFF=YES)
ysize, 1, gdal.GDT_Float32, options=['BIGTIFF=YES'])
But as you didn't specify compression, it should have done that
automatically. Can you indicate the exact values of xsize and ysize you
use ?
> but it didn't work.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210420/28f0af49/attachment.html>
