[gdal-dev] vsis3 worldfile support?
Even Rouault even.rouault at spatialys.com
Tue Apr 27 07:20:21 PDT 2021
Matt,
I've just tested and this works for me. Can't think of a reason besides
a permission problem with the .pgw/.wld files, or if you've set the
CPL_VSIL_CURL_ALLOWED_EXTENSIONS configuration option to "png"
Even
Le 27/04/2021 à 16:04, Cechini, Matthew F. (GSFC-423.0)[Science Systems
& Applications, Inc.] via gdal-dev a écrit :
> Using GDAL 2.4.4, I’m attempting to read a PNG file in S3 with this
> prefix: /vsis3/bucket/prefix/image.png.  Alongside that object are
> also image.pgw an image.wld objects (same content).  When I run
> gdalinfo on the /vsis3 path, I’m not seeing the geolocation
> information.  Am I doing something wrong? Do I need a new version? Is
> this a known limitation?
> Thanks,
> Matt
> Matthew Cechini
> Contractor, Science Systems and Applications, Inc.
> NASA GIBS Systems/Software Engineer
> 410.205.6272
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210427/9309b3dc/attachment.html>
