[gdal-dev] Reading binary data from FileGDB
Paul Harwood runette at gmail.com
Fri Apr 30 08:18:40 PDT 2021
I am going to go out on a couple of limbs here :
- About 3041 - it is what it is!
As it happens I have been thinking about learning more about the SWIG side
of things and I had a quick look. Not a trivial issue - that method was
excluded for a reason. There is some complicated marshalling to do.
Even if it was easy - especially with 3.3.0 in the launch tubes it would be
months before anything would come out in a release.
- About 3040 - looks like a bug. But you have the same problem with launch
timetables even once someone fixes it (unless you fix it and then create
your own temp build).
So - the best suggestion I can think of is probably facile (so don't take
it the wrong way ) - but is there no way that you could do it in Python?
On Fri, 30 Apr 2021 at 06:14, srweal <steve_wealands at essolutions.com.au>
wrote:
> Hi,
> I'm after advice. I need to read a BLOB field from various features within
> a
> FileGDB. I need to work with this data either in C# code (via the GDAL C#
> bindings), or else have it directly read into a SQL database (e.g. via
> ogr2ogr).
> I've hit up against a couple of problems doing this that I don't know how
> to
> fix in the GDAL source which I've documented here but had no feedback on:
> https://github.com/OSGeo/gdal/issues/3040
> https://github.com/OSGeo/gdal/issues/3041
> Am wondering if anyone on the list can suggest a better approach that would
> work?
> Thanks. Have been stuck on this for a while now with no real way forward.
> Steve
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210430/ef839514/attachment.html>
