[gdal-dev] Fw: Building GDAL with ECW support
pteroglossus at pm.me pteroglossus at pm.me
Fri Feb 5 17:38:39 PST 2021
Regarding the compilation of GRASS: pointing to my existing install of GDAL prior the compiling process did not work. So I followed Richard's advice and restarted the whole process of compiling GDAL, without the --prefix, then configured and compiled GRASS, and it worked!
I mean I was able to start GRASS GIS, but it won't import my .ecw:
"r.import input=/media/k/Data/Data/Perso/Carto/SCAN50_2012.ecw output=SCAN50_2012
ERROR: Unable to open datasource </media/k/Data/Data/Perso/Carto/SCAN50_2012.ecw>
ERROR: Unable to read GDAL dataset </media/k/Data/Data/Perso/Carto/SCAN50_2012.ecw>"
+ an additional Dialog Box :"Unable to determine number of raster bands"
Gdalinfo is however able to get info from the file and gdal_translate to convert it, which necessarily means my installation has worked!
Any ideas?
Regards,
Kevin
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210206/c71843b7/attachment.html>
