[gdal-dev] Compiling GDAL with HDF4 support
Andrew C Aitchison andrew at aitchison.me.uk
Tue Feb 9 01:49:56 PST 2021
On Tue, 9 Feb 2021, Hernán De Angelis wrote:
> On 2021-02-08 20:22, Markus Metz wrote:
>> Is /usr/local/lib64 known to your system as a path to libraries? Check the
>> env var LD_LIBRARY_PATH or add "/usr/local/lib64" to some file in
>> /etc/ld.so.conf.d/ followed by "ldconfig" as root.
>> You can also set the var LDFLAGS for configure if you have libraries in a
>> nonstandard directory, such as
>> LDFLAGS="/usr/local/lib64" ./configure ...
> Thank you for your suggestion, Markus, but /usr/local/Lib64 is in the library
> path.
What platform are you on ? On most unix systems
 	/usr/local/Lib64
is not the same as
 	/usr/local/lib64
Andrew C. Aitchison					Kendal, UK
