[gdal-dev] Compiling GDAL with HDF4 support
Markus Metz markus.metz.giswork at gmail.com
Tue Feb 9 10:34:36 PST 2021
On Tue, Feb 9, 2021 at 10:54 AM Hernán De Angelis <
variablestarlight at gmail.com> wrote:
> On 2021-02-09 10:49, Andrew C Aitchison wrote:
> > On Tue, 9 Feb 2021, Hernán De Angelis wrote:
> >> On 2021-02-08 20:22, Markus Metz wrote:
> >>> Is /usr/local/lib64 known to your system as a path to libraries?
> >>> Check the env var LD_LIBRARY_PATH or add "/usr/local/lib64" to some
> >>> file in /etc/ld.so.conf.d/ followed by "ldconfig" as root.
> >>> You can also set the var LDFLAGS for configure if you have libraries
> >>> in a nonstandard directory, such as
> >>> LDFLAGS="/usr/local/lib64" ./configure ...
> >> Thank you for your suggestion, Markus, but /usr/local/Lib64 is in the
> >> library path.
Details about the reason for the failure should be at the end of config.log
My wild guess is that a library needed by HDF4 is not linked in.
HTH,
Markus M
> > What platform are you on ? On most unix systems
> >     /usr/local/Lib64
> > is not the same as
> >     /usr/local/lib64
> Thanks, I am aware of that ;-)
> It was a typo in the message.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210209/e64173fd/attachment.html>
