[gdal-dev] Python Wheels for gdal
Idan Miara idan at miara.com
Tue Feb 23 06:13:19 PST 2021
Hi Rob,
Good point.
I don't know - I've added Christoph to this thread.
Christoph - can you share with us any build scripts or source file changes
you make in order to build these wheels?
I was able to combine the cp37+cp38+cp39 from Christoph's wheels for each
platform by extracting the wheel files and repacking them in a single wheel
per platform using a custom setup.py+setup.cfg
The pyd files are very small so the overhead in wheel size is negligible.
https://github.com/talos-gis/gdal-win
Running build_all.bat creates:
gdal-3.2.1-py37.py38.py39-none-win_amd64.whl
gdal-3.2.1-py37.py38.py39-none-win32.whl
(Note that this batch does not build the sources, just repacks the wheels)
Idan.
On Tue, 23 Feb 2021 at 16:02, Robert Coup <robert.coup at koordinates.com>
wrote:
> Hi Idan,
> On Wed, 17 Feb 2021 at 12:24, Idan Miara <idan at miara.com> wrote:
>> From what I can see, the gdal302.dll inside
>> https://www.lfd.uci.edu/~gohlke/pythonlibs/#gdal doesn't depend on any
>> non-windows DLL. All its dependencies are statically linked.
>> Maybe until a better solution is found, and to remedy all the windows
>> users who just want to `pip install gdal`,
>> We could push Christoph Gohlke's wheels to pypi ?
> Do you know if the build scripts for Christoph Gohlke's GDAL/related
> builds are available? I don't think we could push any binaries on behalf of
> GDAL unless people can reproduce or adapt them.
> Rob :)
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210223/beda942b/attachment.html>
