[gdal-dev] The proper way to call gdal "scripts" on Windows?
Idan Miara idan at miara.com
Thu Feb 25 02:16:54 PST 2021
I can't think about a potential security issue with that as long as you
trust your default python interpreter...
So to sum up the workaround:
Saving the following line as c:\Python38\Scripts\gdal_calc.bat (or as the
same name as any other x.py script)
@python %~dp0\%~n0.py %*
and calling gdal_calc (apparently .bat has higher priority then .py) would
work regardless of the py file association.
For anyone who is not familiar with the quirks of windows batch files:
@ = not to echo the command
python = your default python interpreter
%~dp0 means the path of the current batch file (i.e. c:\Python38\Scripts)
%~n0 means the name of the batch file without extension (i.e. gdal_calc)
So running gdal_calc it would essentially call the following:
python c:\Python38\Scripts\gdal_calc.py
Idan
On Thu, 25 Feb 2021 at 12:02, Richard Duivenvoorde <rdmailings at duif.net>
wrote:
> On 2/25/21 10:53 AM, Idan Miara wrote:
> > Actually, it might be a good idea to use a batch file...
> > I've created the following batch file named gdal_calc.bat in the scripts
> folder:
> > @python %~dp0\gdal_calc.py %*
> > Then running gdal_calc works even if *.py is associated with PyCharm.
> > Do you think this issue justifies creating this kind of batch files for
> the scripts to distribute in binary windows wheels ?
> Mmm, /me no windows expert, I don't know.
> But couldn't this be a potential security issue? But I let knowledge to
> Windows/Python packagers....
> Regards,
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210225/3880d740/attachment-0001.html>
