[gdal-dev] gdal_translate receiving "Warning 6: driver GTiff does not support creation option WEBP_LOSSLESS"
Marty J. Sullivan marty.sullivan at cornell.edu
Thu Jan 14 14:09:15 PST 2021
Hello,
I am attempting to create a COG format GeoTIFF with WEBP_LOSSLESS compression using GDAL.
I have compiled GDAL 3.2.1 from source with libwebp 0.4.2 installed from Debian Buster repos (I’ve also tried with libwebp v1.1.0 installed from source, no difference). When I run the ./configure script before compiling, WEBP support is listed as “Yes”
When I try to create a COG with gdal_translate, and setting QUALITY=100, GDAL returns “Warning 6: driver GTiff does not support creation option WEBP_LOSSLESS”
I would expect that WEBP_LOSSLESS would work because the documentation for the GTiff driver states “WEBP_LOSSLESS=True/False: (GDAL >= 2.4.0 and libwebp >= 0.1.4): By default, lossy compression is used. If set to True, lossless compression will be used.”
Here is the command I am running, it works fine when running with another compression (or choosing QUALITY=99 for WEBP)
gdal_translate -of COG -co COMPRESS=WEBP -co QUALITY=100 -co NUM_THREADS=ALL_CPUS -co RESAMPLING=NEAREST -co OVERVIEW_RESAMPLING=NEAREST -co WARP_RESAMPLING=NEAREST -co OVERVIEWS=AUTO -co TILING_SCHEME=CUSTOM -co ZOOM_LEVEL_STRATEGY=UPPER input.tif output.tif
Thanks for any guidance on getting WEBP_LOSSLESS to work!
Marty Sullivan
Cornell University
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210114/f789fd1d/attachment-0001.html>
