[gdal-dev] Considering drivers removal ?
Jeff McKenna jmckenna at gatewaygeomatics.com
Thu Jan 28 18:13:43 PST 2021
I'm also always surprised at how closely users follow the RFCs, what's
coming down the pipe, and the logic behind 'why' a driver or change was
implemented - this is always missing from regular 'official' user docs,
but users like to know why.
+1 for RFCs
-jeff
On 2021-01-28 6:54 p.m., Mateusz Loskot wrote:
> +1 for RFC
> Mateusz Loskot, mateusz at loskot.net <mailto:mateusz at loskot.net>
> (Sent from mobile, may suffer from top-posting)
> On Thu, 28 Jan 2021, 23:35 Kurt Schwehr, <schwehr at gmail.com
> <mailto:schwehr at gmail.com>> wrote:
>     +1 for RFCs for new drivers.
>     I took a couple minute run at what a template for the RFC might look
>     like.  It's painfully rough.  Anyone wanting to edit the doc, let me
>     know off list and I'll give you edit priv.  Or make you own.  You
>     are welcome to take any or none of my draft text if you make your
>     attempt at a template for a New Driver RFC.  Should there even be a
>     template?
>     https://docs.google.com/document/d/e/2PACX-1vTtIU3WJw0APd7fXqfGVAYrBQGgURIzizb9MiXCI1trkj4PxOBZmz9o-Ne_5P7zkymM7dPjVZOCHBXl/pub
>     <https://docs.google.com/document/d/e/2PACX-1vTtIU3WJw0APd7fXqfGVAYrBQGgURIzizb9MiXCI1trkj4PxOBZmz9o-Ne_5P7zkymM7dPjVZOCHBXl/pub>
>     On Thu, Jan 28, 2021 at 1:37 PM Howard Butler <howard at hobu.co
>     <mailto:howard at hobu.co>> wrote:
>         I am also supportive of RFC approvals before someone goes and
>         invests the time to develop a driver. Otherwise it is easy to
>         get in the spot where it's not merged because the community
>         didn't want it included. A nice thing the RFC process would
>         ensure is a full document of the expectations of the driver.
>         Specifically, whether it depends on binary-only SDKs, what
>         features it would support, and *who* is on the hook for
>         responding to issues on it. Another feature of this RFC should
>         be to clarify the deprecation and removal process for drivers
>         that are no longer relevant or no longer have someone providing
>         them attention.
>>         On Jan 28, 2021, at 1:33 PM, Tamas Szekeres
>>         <szekerest at gmail.com <mailto:szekerest at gmail.com>> wrote:
>>         Hi Sean,
>>         I would also be supportive to formalize the driver submission
>>         process.
>>         Best regards,
>>         Tamas
>>         Sean Gillies <sean at mapbox.com <mailto:sean at mapbox.com>> ezt
>>         írta (időpont: 2021. jan. 28., Cs, 17:39):
>>             Hi Tamas,
>>             Are you suggesting that a RFC be required for a new
>>             driver? I would support this 100%.
>>             On Wed, Jan 27, 2021 at 2:17 PM Tamas Szekeres
>>                 David,
>>                 Up to this time the driver writers were highly
>>                 welcomed to author new drivers for the project and
>>                 these effort didn't require a separate RFC in terms of
>>                 the Project Management Committee Guidelines
>>                 <https://gdal.org/development/rfc/rfc1_pmc.html> document.
>>                 Adding new drivers hasn't been considered to be
>>                 substantial changes or something that causes to change
>>                 the API or brings in backwards incompatibility issues.
>>                 However in a real deployment situation the drivers may
>>                 cause issues for the developers, end users and package
>>                 maintainers from several aspects like so:
>>                 1. The drivers may depend on external libraries and we
>>                 don't want to link against those libraries in all cases.
>>                 2. The external libraries may cause license
>>                 incompatibilities, ie linking against that may change
>>                 the license terms of the overall project.
>>                 3. Not all of the drivers are required in a particular
>>                 solution (that applies to the built in drivers, too).
>>                 In a real situation the application may use only a
>>                 limited set of drivers and the existence of the
>>                 unwanted drivers may cause some performance degradation.
>>                 4. Implementing custom compilations (and omitting
>>                 unwanted drivers from the build) may be problematic
>>                 for most of the users or projects utilizing gdal as a
>>                 sub-project.
>>                 In my opinion, the current solution of incubating new
>>                 drivers is fairly minimalistic, we might probably want
>>                 to know what kind of format is being addressed, who is
>>                 the audience, how amount of user might be of interest,
>>                 how the licensing of the dependent project is looking
>>                 like, is the dependent project (if any) maintained
>>                 well enough and can be compiled to each supported
>>                 platforms etc.
>>                 But replying to the question, I think you shoud
>>                 continue the effort, but consider to implement a
>>                 plugin build for that. There are several existing
>>                 drivers are compiled as plugins at the moment, so it
>>                 should not be so difficult.
>>                 Best regards,
>>                 Tamas
>>                 David Brochart <david.brochart at gmail.com
>>                 <mailto:david.brochart at gmail.com>> ezt írta (időpont:
>>                 2021. jan. 27., Sze, 15:29):
>>                     I am currently trying to add a Zarr driver to GDAL
>>                     (see https://github.com/OSGeo/gdal/pull/3411
>>                     <https://github.com/OSGeo/gdal/pull/3411>), but
>>                     from what I can see the trend is to remove
>>                     drivers, so I'm now wondering it I should pursue
>>                     this effort. I'm relatively new to GDAL, but from
>>                     my point of view supporting a lot of formats is
>>                     part of GDAL's success, so maybe the real focus
>>                     should be on implementing a plugin mechanism that
>>                     would allow driver development independently from
>>                     core GDAL. Again, I might not have enough
>>                     background to give valuable feedback.
>>                     Regards,
>>                     David.
>>                     On Wed, Jan 27, 2021 at 12:34 PM thomas bonfort
>>                     <thomas.bonfort at gmail.com
>>                     <mailto:thomas.bonfort at gmail.com>> wrote:
>>                         On Tue, Jan 12, 2021 at 11:36 PM Even Rouault
>>                         <even.rouault at spatialys.com
>>                         <mailto:even.rouault at spatialys.com>> wrote:
>>                             The issue with esoteric/legacy drivers is
>>                             not that much maintenance of the
>>                             actual code of the drivers, in the sense
>>                             of dealing with bug reports,
>>                             questions, etc. (pretty sure they are none
>>                             for the ones I listed). Most of
>>                             them must work reasonably well and be
>>                             feature complete, and most
>>                             vulnerabilities have now been fixed. My
>>                             concern is that this legacy code has
>>                             indirect costs on other GDAL developers
>>                             and users. The psychological cost I
>>                             mentionned. Let's say someone want to turn
>>                             on higher warning levels, and that
>>                             this breaks in tens of drivers. Would he
>>                             have to ping every maintainer and
>>                             wait for them to address the issue ? Or
>>                             maybe he will just give up. Similarly
>>                             for breaking changes in the driver API. As
>>                             Sean mentionned, this is probably a
>>                             serious obstacle to growing up the core
>>                             development team.
>>                         Given that we have a relatively easy way to
>>                         disable individual drivers at compile time,
>>                         could we expand on this mechanism to mark
>>                         problematic drivers as "orphaned" in this
>>                         case? The code would still live in the repo
>>                         but would be effectively disabled until
>>                         someone with sufficient interest invests the
>>                         time/money to update the problematic code and
>>                         re-enable it.
>>                         This will of course create some overhead to
>>                         keep track of which drivers have been
>>                         orphaned from one release to the next, create
>>                         github issues/labels to list which drivers
>>                         need work to be re-enabled, etc... But it
>>                         shifts the burden of maintaining the codebase
>>                         of 250 drivers from the core team over to the
>>                         people/companies who actually need them. I'd
>>                         be willing to contribute the scripts that
>>                         could ease the process of
>>                         orphaning/reintegrating a specific driver.
>>                         Regards,
>>                         Thomas
>>             Sean Gillies
>>         _______________________________________________
>>         gdal-dev mailing list
>>         gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>>         https://lists.osgeo.org/mailman/listinfo/gdal-dev
>>         <https://lists.osgeo.org/mailman/listinfo/gdal-dev>
Jeff McKenna
GatewayGeo: MapServer Consulting and Training Services
co-founder of FOSS4G
http://gatewaygeo.com/
