[gdal-dev] DIMAP driver questions
thomas bonfort thomas.bonfort at gmail.com
Fri Jul 9 12:42:53 PDT 2021
You can open the DIM_*.XML files with gdal, those are the useful ones.
Thomas
On Fri, Jul 9, 2021 at 9:38 PM <Matt.Wilkie at yukon.ca> wrote:
> Hi,
> The DIMAP driver page lists names of the index files to look at. I don’t have any of these filenames in our SPOT6 folder tree. Is the driver description page incomplete or perhaps I’ve been given a different DIMAP version?
> METADATA.DIM (DIMAP 1),
> VOL_PHR.XML (DIMAP 2) or
> VOL_PNEO.XML (DIMAP 2 VHR-2020)
> By pointing gdalinfo at the xml files I think I’ve determined that the index file name is of the pattern “DIM_SPOT6_MS_201508152008275_SEN_1.XML”. Is this right?
> The directory tree I have is:
> $ tree
> Folder PATH listing for volume Data
> Volume serial number is C0000100 AEC2:FADE
> D:.
> └───DS_SPOT6_201508152008275_LM1_LM1_LM1_LM1_W138N63_06499
>     ├───LIBRARY
>     └───PROD_SPOT6_001
>         ├───LIBRARY
>         └───VOL_SPOT6_001_A
>             ├───IMG_SPOT6_MS_001_A
>             │   ├───LIBRARY
>             │   ├───LINEAGE
>             │   └───MASKS
>             ├───IMG_SPOT6_P_001_A
>             │   ├───LIBRARY
>             │   ├───LINEAGE
>             │   └───MASKS
>             └───LIBRARY
> Gdalinfo report and filename listings attached.
> The folders named “lineage” and “mask” have names that indicate useful info however gdalinfo report doesn’t refer to them. Is there some other way to take advantage of them or is that the province of full blown remote sensing software?
> I’m using GDAL Utilities v3.1.4 released 2020/10/20 via Qgis 3.18 on Windows.
> Thanks in advance for your thoughts,
> Matt Wilkie
> Geomatics Developer & Administrator
> Environment | Technology, Innovation and Mapping
> T 867-667-8133 | Yukon.ca
> Hours: 08:30-16:30, Mon-Wed: Office, Thu: Remote, Fri: Away.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
