[gdal-dev] Computing my overviews for GeoTIFF
Even Rouault even.rouault at spatialys.com
Tue Jul 13 09:34:43 PDT 2021
Le 13/07/2021 à 18:24, Javier Jimenez Shaw a écrit :
> Sounds good.
> My next question is how to write the overviews data efficiently.
> I see that there is a method "GDALRasterBand *
> GDALRasterBand::GetOverview ( int i ) ", but for that I need to
> deinterlace the image (copying it), and call it 4 times. Is there any
> trick I am missing while calling GDALRasterBand::RasterIO? Maybe some
> black magic with the pixel and line spaces? The images/overviews I get
> from the GPU are interlaced (RGBARGBA)
> On the other side there is "GDALDataset::RasterIO(...)", but there is
> not explicit way to set the overview level.
You can call GetDataset() on the RasterBand returned by GetOverview().
Note that this will not necessarily return a non-NULL dataset for all
drivers, but it will for GeoTIFF.
Internally though this will go through the GDAL block cache (per band),
so there will be internal deinterlace & reinterlace, at least for
internal overviews, that by default use pixel-interleaving (for external
overviews, band interleaving is used)
> Thanks
> .___ ._ ..._ .. . ._. .___ .. __ . _. . __..  ... .... ._ .__
> Entre dos pensamientos racionales
> hay infinitos pensamientos irracionales.
> On Tue, 13 Jul 2021 at 14:04, Even Rouault <even.rouault at spatialys.com
> <mailto:even.rouault at spatialys.com>> wrote:
>     Javier,
>     You can use the "NONE" resampling method in BuildOverviews() or
>     gdaladdo to create the overviews IFD without allocating any
>     storage, and then you can open the file in update mode to set
>     whatever values you want. APPEND_SUBDATASET=YES will not set the
>     appropriate value for the SubFileType TIFF tag, and thus such
>     pages won't be recognized as overviews
>     Even
>     Le 13/07/2021 à 13:57, Javier Jimenez Shaw a écrit :
>>     Hi
>>     I am computing the overviews of a GeoTIFF on my own (using the
>>     GPU, much faster), and I want to include them in the tif file
>>     (also in the ovr sidecar file).
>>     What is the best way to do it? Just creating a multipage TIFF (I
>>     guess with the option APPEND_SUBDATASET=YES)? Is there anything
>>     else needed (metadata, tiff tags, etc)?
>>     So far I want to do it in RGBA 8 bit images. (In the future I
>>     want to do it also in float32 images with nodata value and any
>>     number of bands, but no hurry).
>>     I am using GDAL 3.3.1
>>     Any help is welcome.
>>     Thanks.
>>     Javier.
>>     _______________________________________________
>>     gdal-dev mailing list
>>     gdal-dev at lists.osgeo.org  <mailto:gdal-dev at lists.osgeo.org>
>>     https://lists.osgeo.org/mailman/listinfo/gdal-dev  <https://lists.osgeo.org/mailman/listinfo/gdal-dev>
>     http://www.spatialys.com  <http://www.spatialys.com>
>     My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210713/844e361e/attachment.html>
