[gdal-dev] Large GeoJSONs and aborting file opening
Simon Eves simon.eves at omnisci.com
Thu Jul 29 09:30:52 PDT 2021
The problematic one in this case is about 30GB, with ~5.9M features, of
property parcels in Florida, each with polygons with 5-10 vertices and 57
(!) other columns. Below is the first feature as printed by ogrinfo. It
appears to have originated as a Shapefile, which we have also converted to
regular GeoJSON (the 30GB one), and linear GeoJSONL/Seq.
The Shapefile version imports with no issues or obvious delays, with
features flowing basically immediately, and the overall process taking
about 7 minutes.
The regular GeoJSON version spends over 20 minutes in the GDALOpenEx call,
and another 10 minutes before features flow (haven't looked yet in what),
after which it takes about the same 7 minutes.
The GeoJSONL/Seq version spends about 12 minutes in GDALOpenEx and then the
same 10 minutes, and then the same 7 minutes.
Note that ogrinfo has the same initial delays (20 minutes and 12 minutes)
before it prints anything.
This is all with GDAL 3.2.2 on Ubuntu 20.04 on a quad i7 4.2 with 32GB and
SSD.
The 7 minutes of import is not the issue, and once features are flowing,
our code is able to be aborted. The issue is the 20-30 minutes where it
can't because it's (seemingly) stuck in GDAL calls.
Simon
______________________________
OGRFeature(fl_parcels):0
  CNTYNAME (String) = ESCAMBIA
  LINK (String) = 27-083S321301060003
  PARCELID (String) = 083S321301060003
  NPARNO (String) = 12-033-083S321301060003
  DORUC (String) = 000
  PAUC (String) = 1
  PARUSEDESC (String) = VACANT RESIDENTIAL
  SPASS_CD (String) = (null)
  IMPROVVAL (Integer) = 0
  LNDVAL (Integer64) = 1069
  JV (Integer64) = 1069
  JV_CHNG (Integer) = (null)
  JV_HMSTD (Integer) = (null)
  AV_SD (Integer64) = 1069
  AV_NSD (Integer64) = 1069
  AV_HMSTD (Integer) = (null)
  JV_CLASS_U (Integer) = (null)
  ONAME (String) = GRAF MABIE PARTNERSHIP
  OADDR1 (String) = 5544 BAKER RD
  OADDR2 (String) = (null)
  OCITY (String) = MILTON
  OSTATE (String) = FL
  OZIPCD (String) = 32570
  PHYADDR1 (String) = (null)
  PHYCITY (String) = PERDIDO KEY
  PHYZIP (String) = 32507
  SLEGAL (String) = LT 6 BLK 3 PERDIDO BAY COUNTRY
  ALTKEY (String) = 103002391
  ACTYRBLT (Integer) = (null)
  EFFYRBLT (Integer) = (null)
  TOTLVGAREA (Integer) = (null)
  NOBULDNG (Integer) = (null)
  NORESUNTS (Integer) = (null)
  PARSPLT (String) = (null)
  LNDSQFOOT (Real) = 14610.000000000000000
  CONSTCLASS (String) = (null)
  SALEPRC1 (Integer64) = (null)
  SALEYR1 (Integer) = (null)
  SALEMO1 (Integer) = (null)
  ORBOOK1 (String) = (null)
  ORPAGE1 (String) = (null)
  SALEPRC2 (Integer) = (null)
  SALEYR2 (Integer) = (null)
  SALEMO2 (Integer) = (null)
  NBRHDCD (String) = (null)
  PUBLICLND (String) = (null)
  TAXAUTHCD (String) = MSTU
  SEC (String) = 8
  TWN (String) = 03S
  RNG (String) = (null)
  CENSUSBK (String) = 12033002604
  SOURCEAGE (String) = ESCAMBIA COUNTY PROPERTY APPRAISER
  SOURCEDATE (Integer64) = 1506643200
  LAT_DD (Real) = 30.334948776670700
  LONG_DD (Real) = -87.417015732515793
  MGRS (String) = 16RDU5991555975
  ACRES (Real) = 0.335475404173654
  EXMPT (String) = (null)
  LU_RES (String) = (null)
  LUCODE (String) = 000
  GCID (Integer) = 3070217
  DESCRIPT (String) = VACANT RESIDENTIAL
  FLAG (String) = (null)
  FGDLAQDATE (Integer64) = 1509494400
  AUTOID (Integer) = 3070217
  Shape_Leng (Real) = 161.443473611912992
  Shape_Area (Real) = 1357.620793937390090
  POLYGON ((-87.4169063602653 30.3347107536787,-87.4169237108049
30.3346997733855,-87.4172722303389 30.3349846323649,-87.41724423478
23 30.3350359296124,-87.4172384512691 30.3351985804435,-87.4171183385966
30.335195856325,-87.4169790313658 30.3350555432658,-87.4167
283286418 30.3348031641612,-87.4167416558679
30.3347974225575,-87.4167635326352 30.3347875319118,-87.4167852417644
30.3347773059899,
-87.4168030952182 30.334768463082,-87.4168206972148
30.3347594525361,-87.4168382153925 30.3347501905331,-87.416855482113
30.33474067
7073,-87.4168725811955 30.3347309121558,-87.4168895964589
30.334720937691,-87.4169063602653 30.3347107536787))
On Thu, Jul 29, 2021 at 6:49 AM Mike Flannigan <mflan at mflan.com> wrote:
> I would like to hear more about large GeoJSON files.
> How large are they?
> My GeoJSON files contain linear features only.  My
> largest one is 50.2 MB with 1,230,000 newlines in it.
> Next biggest one is 12 MB with 280,000 newlines.  These
> and about 140 other geojsons are open in the same project
> and I have no problems.  In fact I converted from
> SHP to geojson 2 years ago because I used to have problems
> with SHP linear files.
> I use QGIS 3.16.8 on Linux Mint.
> Mike
> On 7/28/21 2:36 PM, gdal-dev-request at lists.osgeo.org wrote:
> > Date: Wed, 28 Jul 2021 12:22:12 -0700
> > From: Simon Eves<simon.eves at omnisci.com>
> > To:gdal-dev at lists.osgeo.org
> > Subject: [gdal-dev] Large GeoJSONs and aborting file opening
> > Message-ID:
> CAJf0KTRsaskSOsPv8tbA+iTB+TqL_ui5y4n05WGLDw_3guRs4w at mail.gmail.com>
> > Content-Type: text/plain; charset="utf-8"
> > Dear All,
> > I am aware that some improvements were made in the 2.3 timeframe with
> > regards to dealing with large GeoJSON files, although even in 3.2, it's
> > still very slow and memory hungry.
> > Our system allows for aborting imports, but this only works reliably once
> > it has actually got to the stage of reading features from the file. With
> > the GeoJSON, it just sits in the GDALOpenEx call for ages.
> > My question, therefore, is whether it might be practical to run the
> > GDALOpenEx in a separate thread with a future to return the resulting
> > handle, such that it could be monitored and killed if necessary?
> > Mainly I would be concerned that killing the thread might trash some
> global
> > GDAL state that might then not be recoverable, or that the open relies on
> > some TLS for the process thread and therefore might not work properly.
> > We're going to try it anyway, but opinions welcomed, thanks!
> > Simon
<http://www.omnisci.com/>
Simon Eves
Senior Graphics Engineer, Rendering Group
100 Montgomery St (5th Floor), San Francisco, CA 94104, USA
Email: simon.eves at omnisci.com | Cell:  +1 (415) 902-1996
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210729/ec3f74ee/attachment-0001.html>
