[gdal-dev] Introducing the cogger and godal projects
Javier Jimenez Shaw j1 at jimenezshaw.com
Tue Jun 8 07:43:25 PDT 2021
That sounds reasonable.
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
On Tue, 8 Jun 2021 at 10:59, thomas bonfort <thomas.bonfort at gmail.com>
wrote:
> There is no c++ version, although there are no specific go constructs
> that would prevent a port to c++ if you really wanted to.
> It could also be possible to export a C function from the go code,
> exposed as a shared library, that would only work on local files
> and who's signature would be something like:
> int rewrite(char *outputfilename, char *intpufilename);
> thomas
> On Tue, Jun 8, 2021 at 10:32 AM Javier Jimenez Shaw <j1 at jimenezshaw.com>
> wrote:
> > Thanks Thomas!
> > I see this is in Go. Is there a C++ version of it? Or how easy is to use
> it from C++ code?
> > Thanks.
> > On Fri, 4 Jun 2021 at 18:48, Even Rouault <even.rouault at spatialys.com>
> wrote:
> >> I haven't benchmarked cogger but I'd expect it to be much faster than
> gdal_translate -of COG (if your input is GeoTIFF and always properly tiled
> and compressed of course!). gdal_translate -of COG uses generic GDAL API to
> acquire input data, which implies decompression / recompression. And in
> particular, if using input GeoTIFF with lossy compressed methods such as
> JPEG or WebP, cogger will avoid adding any new loss.
> >> Le 04/06/2021 à 18:28, thomas bonfort a écrit :
> >> I haven't extensively used -of COG (the cogger code actually predates
> the cog driver) but iirc there are at least some cases where it uses an
> intermediate file, which would imply that cogger does offer some speedups.
> I'll let Even confirm...
> >> Regards,
> >> Thomas
> >> Le ven. 4 juin 2021 à 18:14, <Matt.Wilkie at yukon.ca> a écrit :
> >>> Is cogger specifically for the scenario where your converting a large
> imagery library that already exists, but isn't cloud optimized? i.e. Does
> it offer any advantages over the one step `gdal_translate -of cog ...` when
> starting fresh?
> >>> Cheers,
> >>> Matt
> >>> Geomatics Analyst | Environment | T 867-667-8133 | Yukon.ca
> >>> Hours: 08:30-16:30, Tue-Wed: Office, Thu-Fri: Remote.
> >> _______________________________________________
> >> gdal-dev mailing list
> >> gdal-dev at lists.osgeo.org
> >> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> >> http://www.spatialys.com
> >> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210608/362ea352/attachment.html>
