[gdal-dev] QGIS - No module named GDAL
Idan Miara idan at miara.com
Tue Jun 8 11:41:40 PDT 2021
`import gdal` was deprecated. It got removed in 3.3.
Please use `from osgeo import gdal`
Idan.
On Tue, 8 Jun 2021, 21:11 Bill Eggers, <beggers359 at gmail.com> wrote:
> Somewhere between installing BlenderGIS, OSGEO4W testing version, and
> ArcGISPro, the QGIS plugins that relied on GDAL quit working. I’ve tried
> uninstalling and re-installing OSGEO4W and the standalone QGIS 3.18..3-2
> and a few other tips like specifying the Python path, but nothing worked. I
> suspect something happened when I was installing the BlenderGIS addon. It
> called for a separate installation of Python and GDAL wheel. I’ve copied
> the error message below. The problem isn’t just related to the QGIS CWSI
> plugin, this is just an example of what I see from several plugins. Can
> anyone help me fix this?
> Kind regards,
> Bill
> Couldn't load plugin 'cwsi' due to an error when calling its
> classFactory() method
> ModuleNotFoundError: No module named 'gdal'
> Traceback (most recent call last):
>   File "C:\PROGRA~1/QGIS31~1.3/apps/qgis/./python\qgis\utils.py", line 335, in _startPlugin
>     plugins[packageName] = package.classFactory(iface)
>   File "C:\Users/beggers/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\cwsi\__init__.py", line 35, in classFactory
>     from .cwsi import CWSI
>   File "C:\PROGRA~1/QGIS31~1.3/apps/qgis/./python\qgis\utils.py", line 799, in _import
>     mod = _builtin_import(name, globals, locals, fromlist, level)
>   File "C:\Users/beggers/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\cwsi\cwsi.py", line 43, in
>     import gdal
> Python version: 3.9.5 (tags/v3.9.5:0a7dcbd, May  3 2021, 17:27:52) [MSC
> v.1928 64 bit (AMD64)]
> QGIS version: 3.18.3-Zürich Zürich, 735cc85be9
> Python Path:
>    - C:/PROGRA~1/QGIS31~1.3/apps/qgis/./python
>    - C:/Users/beggers/AppData/Roaming/QGIS/QGIS3\profiles\default/python
>    C:/Users/beggers/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins
>    - C:/PROGRA~1/QGIS31~1.3/apps/qgis/./python/plugins
>    - C:\Program Files\QGIS 3.18.3\binC:\Program Files (x86)\ArcGIS\bin
>    - C:\Program Files\QGIS 3.18.3\bin\python39.zip
>    - C:\PROGRA~1\QGIS31~1.3\apps\Python39\DLLs
>    - C:\PROGRA~1\QGIS31~1.3\apps\Python39\lib
>    - C:\PROGRA~1\QGIS31~1.3\apps\Python39\lib\site-packages
>    - C:\PROGRA~1\QGIS31~1.3\apps\Python39\lib\site-packages\win32
>    - C:\PROGRA~1\QGIS31~1.3\apps\Python39\lib\site-packages\win32\lib
>    - C:\PROGRA~1\QGIS31~1.3\apps\Python39\lib\site-packages\Pythonwin
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210608/94f15625/attachment.html>
