[gdal-dev] Converting fid from GeoJSON into GeoPackage
Even Rouault even.rouault at spatialys.com
Mon Jun 21 08:08:30 PDT 2021
Jukka,
Automatic FID preservation requires that the source layer reports a
non-empty column name for the FID column, which isn't the case of the
GeoJSON driver. Mostly only SQL-based drivers will report a non-empty
FID column name.
Even
Le 21/06/2021 à 17:04, Rahkonen Jukka (MML) a écrit :
> Hi,
> Take this GeoJSON
> "type": "FeatureCollection",
> "features": [{
> "type": "Feature",
> "id":12425552,
> "properties":
> "geometry": {
> "type": "Point",
> "coordinates": [26.30578223, 60.26170791]
> Ogrinfo knows the fid
> OGRFeature(one_feature):12425552
> Convert into a new GeoPackage and the native fid is lost
> ogr2ogr -f gpkg one_feature.gpkg one_feature.json
> Running the command with “-preserve_fid” keeps the native fid but
> according to ogr2ogr documentation
> https://gdal.org/programs/ogr2ogr.html
> <https://gdal.org/programs/ogr2ogr.html> that should not be needed:
> “Use the FID of the source features instead of letting the output
> driver automatically assign a new one (for formats that require a
> FID). If not in append mode, this behavior is the default if the
> output driver has a FID layer creation option, in which case the name
> of the source FID column will be used and source feature IDs will be
> attempted to be preserved.”
> Is the error in the documentation or in the GeoJSON-GeoPackage conversion?
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210621/629be37b/attachment.html>
