[gdal-dev] New JPEG 2000 Driver
Andrew C Aitchison andrew at aitchison.me.uk
Mon Mar 1 10:37:54 PST 2021
On Mon, 1 Mar 2021, Greg Troxel wrote:
> I also was unclear on the optional driver situation.  Certainly if
> drivers can link with proprietary libraries, there is absolutely no
> reason to object to a driver because it links so an AGPL3 library.
> I believe that drivers with non-MIT licenses shouldn't be built by
> default even if the prerequisite libraries are available in the build
> environment.  Partly this bias is from pkgsrc, as packaging systems
> typically try to control the build to get a repeatable outcome, and
> partly because having a proprietary library installed is different from
> a decision to make gdal use it and thus end up with possible
> distribrution problems.
> I found
>  https://gdal.org/download.html#development-source
>  https://gdal.org/drivers/vector/index.html#vector-drivers
>  https://gdal.org/drivers/raster/index.html#raster-drivers
> but didn't from that understand if one needs to pass --enable, or if the
> library being found is enough.
> Consulting configure.ac, it seems some drivers are built if the library
> is found, and others are only built if the driver is requested and also
> the library is found.
I take it you are aware of
doc/source/development/rfc/rfc34_license_policy.rst
https://gdal.org/development/rfc/rfc34_license_policy.html
User License Policy
The restrictions on mixing proprietary and reciprocally licensed
software generally applies at the point of distribution. In particular,
it is not intended to prevent the end user from assembling a variety of
components for their own use as they see fit, for their own use. To that
end it is important to provide a mechanism for the end user to
deliberately override the restrictions on mixing reciprocally licensed,
and proprietary components. This is accomplished via the
GDAL_LICENSE_POLICY configuration variable which might typically be set
via the environment or via the --config commandline switch to most GDAL
applications. It may have the following values:
-  "USE_ALL": do not discard any drivers based on licensing
    restrictions.
-  "PREFER_PROPRIETARY": If there is a conflict between proprietary and
    reciprocally licensed drivers, use the proprietary ones.
-  "PREFER_RECIPROCAL": If there is a conflict between proprietary and
    reciprocally licensed drivers, use the reciprocally licensed ones.
In addition to setting this via config variables, there will also be a
configure / nmake.opt declaration to alter the default
GDAL_LICENSE_POLICY. Thus a local build could be configured to USE_ALL
at build time instead of having to set environment variables or
commandline switches. This would not be suitable for software that will
be redistributed.
> For pkgsrc this is not a big issue as our build process hides libraries
> that have not been declared as an explicit dependency.  But I wonder if
> it would be best to document that libraries that are other than MIT
> (really, not MIT-ish) will not be searched for and used without an
> explicit --enable-foo, and adjust.
Andrew C. Aitchison					Kendal, UK
