[gdal-dev] New JPEG 2000 Driver
Even Rouault even.rouault at spatialys.com
Wed Mar 3 12:31:12 PST 2021
> https://gdal.org/development/rfc/rfc34_license_policy.html
As indicated in the top of the RFC, its status is "development" (draft),
which here means stalled/non-adopted given that it was proposed long
time ago. So there's no runtime mechanism to control license compatibility.
> But, I'm worried about something different.  As a packager, I'd like to
> know that unless I take the affirmative step of passing --enable-foo,
> for any GPLish or proprietary foo, I won't end up with a gdal build
> linked with foo just because it happened to be present in my build
> environment.
This should normally be the case. One of the few GPL dependencies is
Poppler and must be explicitly enabled with --with-poppler . Similarly
with MySQL. All proprietary dependencies need also to be explicitly
enabled AFAIK (you actually need to point to their SDK).
GEOS (LGPL) is enabled by default is found.
Even
http://www.spatialys.com
