[gdal-dev] problem: gdal_grid, output ers raster file
Even Rouault even.rouault at spatialys.com
Wed Mar 3 14:11:44 PST 2021
This is a "well known" behaviour of gdal_grid in which it writes raster
with a bottom-left corner origin, whereas most other GDAL utilities use
a top-left corner origin. The ERS driver doesn't support such
convention. The workaround you can use is to output gdal_grid as a TIFF
(tmp.tif), then use "gdalwarp tmp.tif out.ers" to flip the origin to a
top-left one.
Even
Le 03/03/2021 à 22:55, Ron Palmer a écrit :
> Looks to me like the ERMapper ERS driver has a bug, using the bottom
> left corner to georef the raster, instead of top left. I can only use
> it if I use local coordinates, any negative northings are plotted
> towards the north. ERS is the main raster format I use.
> I am happy to assist in sorting out the ERS format if the person
> behind it is willing to have a look at it.
> Thanks,
> Ron
> On 17/02/2021 4:55 pm, Ron Palmer wrote:
>> I am having issues with outputting ers raster file from gdal_grid. I
>> import a csv as shape, then grid it and output as ers. The Y coords
>> are all negative as it is in fact a section I simply grid as a 2D
>> raster. Although the shape file plots as I expect it, the ers is
>> flipped upside-down, and hung at the lowest Y value. Please note, if
>> I use GS7BG it works fine.
>> How do I get an ERS output that matches the shape file/data points?
>> I have created a simple example... however, I am new to GDAL, and
>> this is my first post, so please let me know if there is anything
>> else I should provide.
>> Thanks
>> Ron
>> These are the commands:
>>   711  ogr2ogr -f "ESRI Shapefile" xc_zc.shp new.csv -oo
>> X_POSSIBLE_NAMES=xc -oo Y_POSSIBLE_NAMES=zc
>>   712  gdal_grid -zfield Value -a linear:radius=5 xc_zc.shp -of ERS
>> xc_zc.ers
>> here is the content of the data
>> xc,zc,Value
>> 1.25,-0.625,5
>> 3.75,-0.625,5
>> 6.25,-0.625,5
>> 8.75,-0.625,5
>> 11.25,-0.625,5
>> 1.25,-1.938,4
>> 3.75,-1.938,4
>> 6.25,-1.938,4
>> 8.75,-1.938,4
>> 11.25,-1.938,4
>> 1.25,-3.381,3
>> 3.75,-3.381,3
>> 6.25,-3.381,3
>> 8.75,-3.381,3
>> 11.25,-3.381,3
>> 1.25,-4.969,2
>> 3.75,-4.969,2
>> 6.25,-4.969,2
>> 8.75,-4.969,2
>> 11.25,-4.969,2
>> 1.25,-6.716,1
>> 3.75,-6.716,1
>> 6.25,-6.716,1
>> 8.75,-6.716,1
>> 11.25,-6.716,1
>> I have attached a jpg of my output (not sure whether the mailing list
>> allows attachments...)
>> <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient>
>> 	Virus-free. www.avg.com
>> <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
> *Ron Palmer*MSc MBA
> Principal Geophysicist
> 0413 579 099 ron.palmer at pgcgroup.com.au
> www.pgcgroup.com.au <URL:www.pgcgroup.com.au>
> */PGC Geophysics - We specialise in Electrical Surveys!/*
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210303/5b8b85e5/attachment.html>
