[gdal-dev] Finding the Map-Tiles(x, y) in a given Bounding box and zoom level
Travis Kirstine traviskirstine at gmail.com
Thu Mar 11 05:44:27 PST 2021
You could get the "bbox" list from mercantile.tiles and then get the bounds
for each tile using mercantile.bounds and then check the intersection with
your irregular polygon, this would be fairly slow depending on the bounds /
zoom.
I'm not aware of any other libraries.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210311/cc3fef16/attachment.html>
