[gdal-dev] Motion: RFC 78: gdal-utils package
Idan Miara idan at miara.com
Wed Mar 24 14:07:51 PDT 2021
Hi Alan,
Thanks for your comment.
That was actually my original idea, but while I was planning to implement
it appeared that it requires much more additional work, mainly because the
tests of the core and the utils are not separated and tested as a single CI
pipeline.
I also didn't want to make such a disruption especially before I know that
the general idea is accepted.
Many drafts later I ended up implementing it the way I believe would be the
most future compatible and the least disruptive.
It might be a good idea to reconsider that later so we can take it one step
at a time.
Idan
On Wed, 24 Mar 2021, 22:51 Alan Snow, <alansnow21 at gmail.com> wrote:
> One recommendation I have for this RFC would be to remove gdal_utils
> entirely from the main GDAL repository and into its own repository.
> The main reason would be to test against multiple versions of GDAL to
> ensure compatibility. Compatibility across versions is a main goal of this
> RFC if I understand correctly, so that is why I bring it up.
> Hope that is helpful,
> Alan
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210324/03313d82/attachment-0001.html>
