[gdal-dev] Cannot compile 3.3.0 without geos
Javier Jimenez Shaw j1 at jimenezshaw.com
Tue May 4 01:41:48 PDT 2021
Hi
I am trying to compile the new release 3.3.0 in Ubuntu 18.04 with the
option "--without-geos".
The message is this:
GEOS support disabled
configure: error: GEOS support explicitly enabled, but geos-config could
not be found
I tried also changing to "--with-geo=no", with the same result. (Both
options are equivalent, right?)
Looking at the news, I see one entry related:
* configure: Ensure --with-geos/sfcgal fail if unavailable.
Should I do something different to disable geos?
Thanks
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210504/1200541f/attachment.html>
