[gdal-dev] ubuntu installation issue: free(): invalid pointer, Aborted (core dumped)
Greg Troxel gdt at lexort.com
Sat May 8 05:59:06 PDT 2021
Bryan Keith <bryandenniskeith at gmail.com> writes:
> Hello,
> I am trying to install GDAL on Ubuntu.  When I check the installation,
> I get this:
> ogrinfo --version
> GDAL 3.2.1, released 2020/12/29
I would ask Ubuntu.  As no one else has reported an issue like this that
I can remember, and ogrinfo --version works in the obvious way for me,
it's quite possible this is related to something Ubuntu did in
packaging.
It's also possible that it's a latent and usually harmless gdal bug that
is being triggered by higher security settings.  So my other suggestion
is to rebuild the package from soruce using the Ubuntu mechanisms but
turning on debug symbols and run it under a debugger.  How to do that is
out of scope for this list and should also be addressed to Ubuntu.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210508/01d3dd06/attachment.sig>
