[gdal-dev] [External] : Re: Build GDAL on windows with dependency on PROJ
Fengting Chen fengting.chen at oracle.com
Fri May 14 13:51:21 PDT 2021
Thank you!
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Mateusz Loskot
Sent: Thursday, May 13, 2021 7:08 PM
To: gdal-dev at lists.osgeo.org
Subject: [External] : Re: [gdal-dev] Build GDAL on windows with dependency on PROJ
On Fri, 14 May 2021, 00:42 Fengting Chen, <fengting.chen at oracle.com<mailto:fengting.chen at oracle.com>> wrote:
However, I couldn’t find the PROJ source code with makefile for Windows. I am wondering how is PROJ built on Windows in order to build GDAL 3.3 on Windows?
RTM https://proj.org/install.html#cmake<https://urldefense.com/v3/__https:/proj.org/install.html*cmake__;Iw!!GqivPVa7Brio!PJzJ45gzKY-UYYnKUJUgIKKPRqvhZgYR-Bloa9uTdaUcasw4OLF1aSdmGm6ANe-D0bA$>
There is proj mailing list.
ML
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210514/d394a237/attachment.html>
