[gdal-dev] RPC to geotransform converting
Even Rouault even.rouault at spatialys.com
Tue May 18 13:57:42 PDT 2021
Denis,
if the view angle is off-nadir, you generally need to use the -to
RPC_DEM= option with a DEM covering the area of interest (and make sure
the values it contains are WGS 84 ellipsoidal elevations) to get
accurate results.
Even
Le 18/05/2021 à 22:50, Denis Rykov a écrit :
> Hi,
> I have a GeoTIF file and file with RPC information next to it (*.txt).
> Is there a way to transform this raster to a normal geotiff without
> displacement (with geotransform inside) or is it fundamentally impossible?
> I've tried to achieve it with gdalwarp but in this case the result of
> the transformation has about 5 meters (10 pixels) x-displacement (I
> use QGIS to visualize it).
> Denis
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210518/9655caf0/attachment.html>
