[gdal-dev] RFC 84: Migrating build systems to CMake
Paul Harwood runette at gmail.com
Mon Oct 4 05:41:34 PDT 2021
I am not sure if I should be posting this here or on the bug - so I am
starting here.
The RFC does not mention (either positively or negatively) the SWIG
bindings.
Just for the avoidance of doubt :
- It should probably be made clear in the doc if the SWIG bindings are to
be included in the CMAKE build process, and
- I ask the question, in all innocence and without any prejudice on my
behalf or even idea of what the answer would be, since if there were to be
a better way of organising things then a major refactor of the build
process would be the correct time to implement it.
Paul
On Mon, 4 Oct 2021 at 12:49, Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi,
> Please find at https://github.com/OSGeo/gdal/pull/4590 a RFC that
> proposes:
> - to develop a CMake build system, officially integrated in the source
> tree.
> - and remove the current GNU makefiles and nmake build systems, when the
> CMake build system has matured enough and reached feature parity.
> Best regards,
> Een
> http://www.spatialys.com
> My software is free, but my time generally not.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211004/24873125/attachment.html>
