[gdal-dev] running PROJ-data/regenerate_index_html.py
Javier Jimenez Shaw j1 at jimenezshaw.com
Thu Oct 7 09:17:02 PDT 2021
Hi
On the contribution process of PROJ-data, there is a step where you should
run "regenerate_index_html.py". For that you need GDAL, and a recent enough
one.
What I do is to use a docker image: osgeo/gdal:alpine-normal-latest (so I
am sure I am up to date)
However, the script also requires "git", that is not present in that docker
image.
Could we include "git" in that GDAL docker image? Is there a better option?
Thanks
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211007/5334311e/attachment.html>
