[gdal-dev] ogr2ogr changes field length
matteo matteo.ghetta at gmail.com
Thu Oct 7 23:10:52 PDT 2021
Hi Even,
> If you add -lco RESIZE=YES fields will be resized to their minimum size.
> See https://gdal.org/drivers/vector/shapefile.html#layer-creation-options
yep I see. I also read
* String fields without an assigned width are treated as 80 characters
does it mean that if a field is set as TEXT in PG (without length
definition) the conversion to shapefile is automatically set to 80 and
what we can do is to resize the field length only to have less characters?
Cheers!
Matteo
