[gdal-dev] ogr2ogr.exe v3.3.1 only results in blank table
Even Rouault even.rouault at spatialys.com
Mon Oct 18 11:22:00 PDT 2021
Note: already reported at https://github.com/OSGeo/gdal/issues/4674
Le 18/10/2021 à 19:59, laburlet at gmail.com a écrit :
> I have been using ogr2ogr.exe v2.1.0 to import SHP files to MSSQL for
> several years, no problem.
> Recently installed GDAL 3.3.1 and this version of ogr2ogr no longer
> imports SHP, only creates empty table.
> Steps to reproduce the problem.
> I have tried both versions on same machine - v2.1.0 works and v 3.31
> does not
> The command line for v2.1.0 is:
> *c:\OSGeo4w_2016*\bin\ogr2ogr.exe -overwrite -progress -f
> "MSSQLSpatial" -lco SCHEMA=QGIS
> "MSSQL:server=xxxx_17;database=DHLog;trusted_connection=yes"
> "d:\temp\FRO_ELs-MLs.shp" -nln QGIS.frome_els_mls
> The command line for v3.3.1 is same, other than using the new EXE
> *c:\OSGeo4w*\bin\ogr2ogr.exe -overwrite -progress -f "MSSQLSpatial"
> -lco SCHEMA=QGIS
> v2.1.0 imports the SHP just fine to MSSQL, but v 3.3.1 only creates
> the table and then no records
> Attached is the SHP file and its ancillaries
> Operating system
> Win 10 Pro, 64 bit
> With thanks
> Luke B
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211018/2ef4c2aa/attachment.html>
