[gdal-dev] Does OAPIF paging work as supposed?
Even Rouault even.rouault at spatialys.com
Mon Sep 27 06:47:17 PDT 2021
Jukka,
your analysis is completely correct. Whether this is expected or not
probably depends on situations. Should we have a
INITIAL_REQUEST_PAGE_SIZE=number open option to overload the number of
features to retrieve specifically in the first request... ??
Regarding the spatial filter, it is passed through the OGR API generally
after having queried the schema, and for most OGR datasources it
wouldn't influence the schema, so there isn't much that can be done
here, except maybe adding a BBOX=west,south,east,north open option.
One option to avoid both issues would be for the service to publish
DescribedBy links at the collection level that would point to a XML
schema (using a GML Simple Feature schema profile, such as the one
understood by the GML driver) or a JSON schema (not "too" complicated
too). Both are handled by the driver.
Even
Le 27/09/2021 à 15:21, Rahkonen Jukka (MML) a écrit :
> Hi,
> I tried to read a relatively small BBOX from an OAPIF server but the
> process feels rather slow and I do not quite understand what I am
> seeing in the log.
> ogr2ogr -f GPKG test.gpkg
> OAPIF:https://avoin-paikkatieto.maanmittauslaitos.fi/maastotiedot/features/v1/?api-key=xxxx
> <https://avoin-paikkatieto.maanmittauslaitos.fi/maastotiedot/features/v1/?api-key=xxxx>
> -spat 25 65 25.1 65.1 -oo PAGE_SIZE=10000 --debug on --config
> cpl_curl_verbose yes
> Excerpts from the log:
> HTTP:
> Fetch(https://avoin-paikkatieto.maanmittauslaitos.fi/maastotiedot/features/v1/collections/osoitepiste/items?api-key=xxxx&f=json&limit=10000
> <https://avoin-paikkatieto.maanmittauslaitos.fi/maastotiedot/features/v1/collections/osoitepiste/items?api-key=xxxx&f=json&limit=10000>)
> HTTP: These HTTP headers were set: Accept: application/geo+json,
> application/json
> > GET /maastotiedot/features/v1/collections/osoitepiste/items?api-key=xxxx&f=json&limit=10000 HTTP/1.1
> Host: avoin-paikkatieto.maanmittauslaitos.fi
> Accept-Encoding: gzip
> Accept: application/geo+json, application/json
> * Mark bundle as not supporting multiuse
> < HTTP/1.1 200 OK
> GeoJSON: First pass: 56.54 %
> GeoJSON: First pass: 100.00 %
> HTTP:
> Fetch(https://avoin-paikkatieto.maanmittauslaitos.fi/maastotiedot/features/v1/collections/osoitepiste/items?api-key=xxxx&f=json&limit=10000&bbox=25,65,25.1000000000000014,65.0999999999999943
> <https://avoin-paikkatieto.maanmittauslaitos.fi/maastotiedot/features/v1/collections/osoitepiste/items?api-key=xxxx&f=json&limit=10000&bbox=25,65,25.1000000000000014,65.0999999999999943>)
> > GET /maastotiedot/features/v1/collections/osoitepiste/items?api-key=xxxx&f=json&limit=10000&bbox=25,65,25.1000000000000014,65.0999999999999943 HTTP/1.1
> < Content-Length: 309
> GDALVectorTranslate: 0 features written in layer 'osoitepiste'
> Do I read right that GDAL is first reading one page, in this time
> 10000 features without BBOX, perhaps for resolving the schema, and
> then makes a new query with BBOX? In this case the BBOX query finds
> nothing. Reading 10000 features on the first round and then discarding
> everything feels too expensive. Could it be enough to read for example
> 10 features that is the default page size on the first round instead
> of the full page?
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210927/0f8bb511/attachment.html>
